Dump Truck Rookie
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by mightytrucker, Jul 13, 2016.
  1. mightytrucker
    mightytrucker Bobtail Member
    35
    4
    Dec 2, 2015
    So I'll be start driving a dump truck for a local construction company.
    I'll be hauling into their construction sites.
    Any dump truck vets have good advice for a rookie?
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Watch for power lines
    59MackB61 and BoxCarKidd Thank this.
  4. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,656
    12,695
    Dec 15, 2014
    Charlotte, NC
  5. Blackshack46
    Blackshack46 Road Train Member
    Dump trucks don't stop very well with 24 tons in the box.
    59MackB61 Thanks this.
  6. mightytrucker
    35
    4
    Dec 2, 2015
    I've never driven a tag axle before.
    Any hints to make my life easier?
  7. pattyj
    pattyj Road Train Member
    22,474
    20,136
    Jul 19, 2008
    Sioux City,ia
    Raise the dump slowly which you control the pto and move forward slowly as the material is dumping.Construction guys get mad if it's dumped in one big pile.Like a member said watch those power lines,trees act.At the end of your day clean the dump and leave it raisedl till the morning.your company will probably tell you that.Take the turns nice and slow,dump trks and side dumps tip easy.
    Marky84 Thanks this.
  8. belowspeedlimit
    belowspeedlimit Medium Load Member
    648
    611
    Oil country
    Dump on level firm ground. Drop your air. Oh and the obvious. Make sure your box is down before moving.
    Marky84 and pattyj Thank this.
  9. gwilli89
    gwilli89 Light Load Member
    74
    102
    May 4, 2016
    Illinois
    1) If at all possible, dump on level...flat ground.
    2) You've got a higher center of gravity than a lotta vehicles due to your load...take curves and turns slow. I've seen a lot of guys come in hot and roll.
    3) Watch for power lines.
    4) NEVER be afraid to get out and look....check...ask.
    5) NEVER be afraid to move your truck and reposition if you're not comfortable with where you are dumping. I don't care if there's a line of 100 trucks behind you waiting to dump....the line will be longer if you lay it over. Safety first!!
    6) Always make sure you're dumping where you're supposed to be
  10. TROOPER to TRUCKER
    7,656
    12,695
    Dec 15, 2014
    Charlotte, NC
    Driving a concrete truck taugh me how to drive a truck more than most of my school did.
  11. Big.D
    Big.D Bobtail Member
    21
    10
    Nov 9, 2015
    Eastern iowa
    Raise it up before u back up. There not designed to turn when in reverse as they do when going forward.
    mightytrucker Thanks this.
