DVIR question
Discussion in 'Questions From New Drivers' started by TruckerGonnaBe, Feb 15, 2015.
  1. TruckerGonnaBe
    TruckerGonnaBe Light Load Member
    140
    38
    May 27, 2014
    Western WA
    I read that we no longer have to put in a DVIR when there are no defects as of the end of last year. My question is when there is a defect how often should you put in a DVIR for it?
    Currently, the truck I have has an issue with the truck jake brake. It works but most of the time when I let off the accelerator it won't engage until I pop the accelerator. Once I do that it kicks right on. It's been to Kenworth for repairs and into the TSI shops in French Camp (twice) and Spokane (once) for repairs to it but so far it's not repaired. STT said that I should only list it about once a week as a reminder.
    How often should I put in the DVIR? Daily or weekly?
    Also if I put in a trailer condition report for damage I find to the trailer I picked up do I still have to put in a DVIR if there is no new damage? Do I have to put in a DVIR if repairs are done before I leave with the trailer? IE I swapped loads with someone because I had the hours to deliver but 3 tires were low, 1 was flat, and there was a light out. All the repairs were done before I left the yard. Would I still have to list that on a DVIR even though it was repaired?
    Thank you again. :)
  3. brian991219
    brian991219 Road Train Member
    2,980
    6,031
    Aug 10, 2013
    Lords Valley, PA
    In all the cases you listed the answer is what ever your carrier wants you to do. A defective jake brake is not an issue that requires a DVIR per DOT regulations, it is not a safety device such as a headlight or a foundation brake problem. So, if your company wants it written up until it is fixed then do it daily, if not submit it once and that will be good enough. As for the low/flat tires and light out, if they were fixed before you left the yard that means you caught them on your pre-trip so no report is required unless your shop needs one before doing the repairs. The DVIR is to be completed at the end of the day with your post trip, so unless your company wants a report filed for this scenario then no you do not need to put it on your post trip DVIR since the problems have been already corrected.
    TruckerGonnaBe Thanks this.
  4. TruckerGonnaBe
    140
    38
    May 27, 2014
    Western WA
    The company hasn't told me what they want. I've just talked to STT and followed what he said. I'll have to ask them.
    Thank you. :)
  5. Clyde07
    Clyde07 Heavy Load Member
    809
    1,927
    May 28, 2013
    You definitely don't work for my company. The way they do it is the drivers never report or repair trailer defects. They get rid of the trailer as soon as they can and pass the problem on to the next driver, which seems to usually be me.
  6. TruckerGonnaBe
    140
    38
    May 27, 2014
    Western WA
    LOL Clyde07 I get that a LOT! This trailer had just gotten to the yard a couple of hours before I took off with it. The guy dropped it and took off for the bobtail area to sleep. Sad thing is that he brought it over night so how nobody noticed the marker light out I have no idea. I noticed it right off.
    I've had several trailers that a pre-post trip would have easily found the problems. Several trailers have had their ABS light unplugged so the previous driver don't have to deal with getting the wiring fixed. I dislike having to waste my time trying to correct problems only to have the people who dropped it get away with it. It makes me look bad because I had to wait around somewhere to get it repaired but I don't want to risk having problems with DOT if I just run with it the way I get it.
  7. rearview
    rearview Medium Load Member
    325
    9,532
    Nov 8, 2014
    Tenakee Springs
    my thinking is this.
    They changed the law to not everyday. Reason: driver laziness and company paperwork amount.
    I still do 2 a day.
    Why?
    To create a paper trail to show I look after the equipment because the law of probability always allows for the unexpected.
    Records are used in defense, things happen. See forum section trucker accidents.
  8. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    For what it is worth, I still do a DVIR, I could care less about what is said (by the Gov rule makers) that we no longer need to. The reason(s) why I continue are, well, many.
    1) I am old and do not accept change well
    2) No matter what, I want to make sure that if I drop my trailer, and someone else see's something that I did not write up, I'll be nailed for it. (for the record however, we stay hooked up to the same trailer each day, we only switch trailers when one has to go in for service.
    3) See number 1 reason.
  9. LoneCowboy
    LoneCowboy Road Train Member
    1,466
    3,600
    Oct 6, 2009
    Colorado
    holy smokes, we work at the same company. :-(
  10. BROKENSPROKET
    BROKENSPROKET Medium Load Member
    675
    172
    Jan 22, 2011
    Wisconsin
    What I read was that there is a proposal to do away with the requirement of documenting a VI if no defects were found. A DVIR will have to be done when a defect is found.
    Its not a rule YET.
  11. brian991219
    2,980
    6,031
    Aug 10, 2013
    Lords Valley, PA
    BrokenSprocket, as of Dec, 15, 2014 you no longer had to complete a no defect DVIR, per FMCSA. However, if your company wants you to then you still do, it just is no longer a government requirement. It is still a good idea as a CYA move, just noit legally required as of 12/15/14.
