DynaMat, has anyone done it?
Discussion in 'Ask An Owner Operator' started by LoneRanger, Mar 27, 2022.
  1. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    The title says it all.
    no matter what I do the #### Apu keeps me awake and I wake up when it kicks on. I just couldn’t get use to it. So my only choice is to Dynamat the cab.
    I’m wondering if anyones had it done and where it was done?
    also if you have done it yourself, how big of a project is it? I assume the. Whole interior needs to come out.
  3. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,986
    Apr 21, 2021
    Self adhesive. I never heard of anyone doing it to their semi.
    Rideandrepair and LoneRanger Thank this.
  4. Axl99
    Axl99 Bobtail Member
    20
    59
    Dec 22, 2011
    Harlan Ia
    It's is a big project to do it right you pretty much strip the whole cab and sleeper we had about a week into it when we restored a Peterbilt 359. It turn out great for quiet but I would not do it to my 389
  5. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    I did the cab of my '03 379 many years ago and yes, it was quite a job (at least for me) to strip out the interior and I didn't pull the headliner.
    To be honest, it didn't make that much difference in sound reduction considering the work involved.
    Where it really made a difference was the doors, it got rid of the "tinny" sound, if that makes any sense.
  6. DUNE-T
    DUNE-T Road Train Member
    7,043
    17,155
    May 10, 2015
    Detroit, MI
    How about these?
    Siinman, Rideandrepair and LoneRanger Thank this.
  7. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    I trained myself to sleep with a loud fan in the cab, nothing wakes me anymore.
    LoneRanger Thanks this.
  8. Long FLD
    Long FLD Road Train Member
    12,832
    53,689
    Mar 4, 2015
    I did the floor in my FLD when I was replacing the carpet. Seemed to help with keeping noise down and insulated the floor better. Not sure if I’d be up for stripping and entire interior to do the whole cab.
  9. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Learn to enjoy it. If it works, it is warm and cozy)
    It is a lot harder for me to fall asleep when reefer is off. When it works, everything is peachy, happy sleeping.
    On the other note, you have not yet got tired well, as it seams. Few days no good sleep and bomb me, I'm out)
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Did the floor of the sleeper and cab. It helped quiet down the RTOO whine in top gear and the heat stays in quite a bit longer
    LoneRanger and Rideandrepair Thank this.
  11. Rideandrepair
    17,548
    56,853
    Aug 8, 2015
    I just bought some for the floor. It supposed to cut down noise transference vibration. It’s butyl rubber, same rubber used for inner tubes. A second closed cell sound and heat absorbing mat on top of it is suggested. There’s also combo all in one mats. Second skin has one. I used the Siless brand. It’s a lot less money. has another 50mil deadening on bottom, along with absorbing foam, and a strong top layer. Still cost over $200 to do the whole floor. The top mat is similar to a neoprene foam mat. Looks to be the same as original floor mat, only thinner. Depending on how much space is available. A thin layer of thick mass butyl rubber for vibration, and the thickest closed foam rubber, like neoprene would work best. Thicker the better. Other options are lightweight and much cheaper double sided foil mats. Some are just bubble or double bubble wrap. Others are more durable. A combination of butyl deadener, foil in layers and thick foam might be best for walls. Might as well consider heat/cold insulation factors as well. Get the benefits of both.
  12. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I believe @fortycalglock did this to a Western Star several years ago.
    cke and LoneRanger Thank this.
