Dynasys APU ac issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chipperrr, Jun 16, 2024.
  1. Chipperrr
    Chipperrr Light Load Member
    58
    10
    Nov 27, 2018
    Have a Dynasys gen 2, About 4500 hours. It works great. My 1 problem is that once you start up the unit the ac takes a few hours to kick in!! But once it kicks in it’s super cold and will work until I move the truck……. Then the process starts all over again.
    I’ve changed the high pressure switch & the capacitor by the motor, same issue happened.
    ANY ADVICE???
  3. Chipperrr
    58
    10
    Nov 27, 2018
    Fyi, ended up being low on freon.... like 2 0z!
    The dynasys gen 2 should have 31-32 oz of freon, not 28.
    Also if your in Joplin, MO... the apu shop Joplin APU, is great, fast & cheap! I would highly recommend.
    Deezl Smoke Thanks this.
