so got my dyno report today ....truck was set at 470 and it peeked at 400 ...3.3 blow by??? is that something i should worry about?
2003 freight century 12.7 l ..13 speed 816k miles
what do you guys think? its def more than 80%
Dyno question....
Discussion in 'Ask An Owner Operator' started by buddyvuk, May 17, 2013.
Its ok, its an 800k engine and your blo by reflcts that but its still acceptable
buddyvuk Thanks this. -
At least you now know your peak HP is from 55-58mph
That seems about normal you have at least 80% of your horsepower going to your wheels so thats a good start...but with that amount of miles I would change that bull gear just to be safe... Detroit recommends having it changed out every 750,000mi...
3.3 inches (in H2O) is normal. I recall the last shop on my dyno run were saying that when you get up around 10-15 inches is when it's time for a rebuild.
If they did the run correctly, you will see the does because they ran it in 7 direct. True 1:1 out of the Trans. Direct gearing.
Everything else looks good to me.buddyvuk Thanks this. -
