Easier way to clear bugs off exhaust stacks?
Discussion in 'Experienced Truckers' Advice' started by Kenworth6969, May 24, 2025.
  1. Kenworth6969
    2,768
    7,984
    Jul 3, 2020
    Bugs melted and fused on exhaust stacks.
    Can get truck wash and next day is bug graveyard again.
    Any easy way to clean?
  3. Rugerfan
    Rugerfan Road Train Member
    7,378
    36,532
    May 3, 2011
    Redding,CA
    Simple green should work
    FLHT Thanks this.
  4. TheLoadOut
    TheLoadOut Road Train Member
    2,253
    10,682
    Nov 6, 2019
    just a shot in the dark
    blairandgretchen Thanks this.
  5. Long FLD
    Long FLD Road Train Member
    11,895
    48,854
    Mar 4, 2015
    When you wash have them RainX everything. That will make them easier to get off.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,680
    18,455
    Nov 1, 2010
    Burnsville, MN
    Some may slide away at first, but bug guts basically neutralize RainX.
    Lonesome Thanks this.
  7. Long FLD
    11,895
    48,854
    Mar 4, 2015
    I’m not talking about the guts sliding off, I’m talking about the elbow grease needed to remove them. I RainX everything every wash. Even hauling cattle it would keep crap from sticking to the sides. I wash at least once per week. Even now that I’m back to being an employee we’re not limited on our washes within reason. Also, this is the reason why people started running dummy pipes with a weed burner under the frame. No heat makes the pipes easier to keep clean.
    Deere hunter, Sons Hero, Oxbow and 2 others Thank this.
  8. rollin coal
    rollin coal Road Train Member
    13,288
    26,799
    Mar 29, 2008
    TN
    The rainX at the blue beacon is good stuff. I always opt for it. Truck gets dusty or slightly dirty and a hard rain will practically wash it clean again.
    Sons Hero, Oxbow and Long FLD Thank this.
  9. wonderkins
    wonderkins Light Load Member
    77
    342
    Jun 19, 2013
    We use pre-soaped s.o.s and bristol pads on ours. Works well and doesn’t scratch up the stacks. You just need a water source to wet the pads.
    Oh yeah, this is all assuming you have a way to get up that high...
  10. Arctic_fox
    4,078
    21,150
    Sep 16, 2016
    Simple green, a bottle of water, a supersoaker, and a stack brush. Takes about 10 mins to clean.
    Spray stacks with simple green, wait 5 mins. Scrub with brush using water bottle to wash dead bugs off between stacks or several times per stack if its really bad. Use supersoaker to clean the simple green off. Gets about 99.9% of them off. 100% if i scrub a little extra.
    Oh and i have an extendable broom handle that works great as both a tarp strap fixer, a spare broom handle and something to thread my windshield and stack brush onto. Best $30 i ever spent for cleaning.
  11. MJM
    MJM Light Load Member
    176
    1,628
    Jan 24, 2011
    Cambridge, WI
    Helps alot to keep bugs from sticking so cleaning is easier.
    Kenworth6969 and JB7 Thank this.
