East trailer with NO securement points
Discussion in 'Flatbed Trucking Forum' started by allan5oh, Sep 7, 2014.
  1. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Saw an East trailer today with absolutely ZERO securement points. The floor had no pullouts or anywhere you could put those blue portable things. The trailer had no rubrail, the floor was right to the edge. It had no slider system, no winches or anything like that. The only thing I could think of is either the customer is going to install a rail and it's a narrow trailer, or they're only going to use flat hook straps and portable hand ratchets. There's nowhere to put chains. Any of you guys have an idea? I can get pics tomorrow hopefully.
    edit sept 8th:
    This trailer is 102" wide and has no chain pullouts, chain tiedowns, rub rail, spools, securement points for blue East portables, sliders, ability to accept sliders, ability to accept fixed (unless they want them to stick WAY out) winches or securement points, nailing strips, etc..
  3. snowwy
    snowwy Road Train Member
    20,560
    13,286
    Jul 6, 2009
    underneath the sides of the trailer is usually where the straps hook to. they probably don't haul any chain loads.
  4. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Got any pictures of this trailer so we can get an idea what you are dealing with?
  5. Ruthless
    Ruthless Road Train Member
    8,960
    88,294
    Aug 28, 2010
    The City.
    Used to be an outfit I the metro Boston area that had trailers specced like that. 48' all steel with non sliding tandem all the way to the rear. Used to be a joke because their drivers would use 2" hand straps, and be severely under secured. They only hauled Sheetrock. All one way.
  6. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I'm sure the trailer had deck skirt rails and a frame. They might be installing a Conestoga on it and didn't want the added width of rub rails.
    Cetane+ Thanks this.
  7. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    The only way I can see is using 2" and 4" portables. But that just screams bush league to me, one side swipe from a pickup truck or even a prick with a knife and your load is all over the road. However I did remember one thing, NO conspicuity tape. That screams to me an incomplete trailer.
  8. 2CAN
    2CAN Medium Load Member
    613
    2,756
    Jan 7, 2010
    An owner operator used to run around here with an East flatbed set up like this, he would add the removable strap hooks and winches as needed and when empty there would be no visible gear. Very clean look was his goal, nothing extra when loaded Nothing when empty.:biggrin_25525:
  9. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    There's nowhere to put winches unless they're attached via flat hook. Unless you're talking about the hand winches, hand ratchets, whatever you want to call them. But you simply cannot tighten those enough to be safe for things like pipe loads. That's just suicide. Plus if a vehicle sideswipes you there goes all your straps. Not a smart move.
    Had another look and left even more confused. The trailer is in fact 102" wide, so nothing will be added. I took pictures and will try to post them some time. No nailing strips either. It's a completely plain floor 102" wide.
  10. 2CAN
    613
    2,756
    Jan 7, 2010
    East has a specific aluminum block that is used to attach your 4 inch J hook strap. just like a sliding winch, only, the hook end. Go to Easts website and look at pics of the BST series trailer.
    Is this trailer all aluminum and frame painted white by any chance? If so he had the rubrails capped and polished. Not what I would do but he custom ordered it from East and it is a very nice trailer.
  11. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    No it is not like that.
