eaton 10 speed transmission for volvo replace
Discussion in 'Volvo Forum' started by toniboy, Sep 14, 2012.
  1. toniboy
    toniboy Bobtail Member
    11
    Chicago,Il
    IS ANYBODY CAN TELL ME PLEASE, SOME VERY INPORTANT ADVICE FOR MY VOLVO 2001, VOLVO ENGINE. My transmission is Eaton 10 speed autoshift - RTO-16910C-AS210S. I want to replace mine with Eaton but Manual shift - RTLO-15610B. I think only the drylines are different, but i can change them too. IS it gonna be any problem? Is anybody had that experience before with replacing Auto transmission with manual. Is it gonna fit everything and is everything gonna be ok with the engine too? Thanks.
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Get yourself over to the Eaton web site and compare ratios. I see two different trannys. First thing is the torque rating. Your coming out with a 1600ft/lb and going back with a 1500ft/lb. How much horsepower do you have? Yours has a 1600 ft/lb rating for a reason........and yes, 100lbs of torque rating makes a difference.
    http://www.vibratesoftware.com/html_help/2011/Eaton_Fuller/Transmissions/eaton_9speed_trans.htm
    http://www.vibratesoftware.com/html_help/2011/Eaton_Fuller/Transmissions/eaton_10speed_trans.htm
    http://www.vibratesoftware.com/html_help/2011/Eaton_Fuller/Transmissions/eaton_13speed_trans.htm
    Check it out here......
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    The only problem is to reprogram VEC, else - a half of power
  5. toniboy
    11
    Chicago,Il
    Thank u. My engine is Volvo 465B12. Do u think is going to fit mine tranny with the other manual .
