Eaton 18 speed slave valve leaking air from vent
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, May 13, 2018.
  1. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Thank you. Just came in from greasing all the ujoints till old grease came out. Wiped them down best I could
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    I don't know how much time it takes to replace, I'm was just using a couple hours that a shop may charge you, as an example.
    I personally research if I can do the job properly myself before I attempt it.
    You can also call a transmission shop and ask them what it entails.
    Sometimes they will give you some pointers.
    I've had friends of mine replace splitter valves on 10 speed transmissions and it was just R&R.
    It shouldn't be much different for a 13 or 18 speed.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Roadranger.com
    They have all service manuals, illustrated parts lists, tsb for free to download. Just need your model #.
    Goodysnap Thanks this.
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Thank you for this. I’ll have to try to find model number on this unit which will be diificult
  6. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    What kind of truck is it in. I could look up for you if a KW, Pete, Freightliner or Western star.
  7. Cam Roberts
    1,621
    1,938
    May 13, 2018
    I have a 2002 peterbilt 379 with 18 speed buddy. I tried to open up some of the literature from the link and it won’t let me anyhow becuase my msoffice is expired
  8. boneebone
    2,296
    2,367
    Mar 13, 2009
    There should be a metal plate riveted to the transmission case with the serial number on the passenger side.
    Also look at your driver's side door jamb manufacturer sticker, it should have all your truck's engine and powertrain info printed on it.
  9. boneebone
    2,296
    2,367
    Mar 13, 2009
    If you have a smartphone, it should open up automatically.
    I just clicked on it and it opened up just fine.
  10. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Last six of VIN and will give you trans model if original.
