Eaton 18 speed slave valve leaking air from vent
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, May 13, 2018.
  1. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Your transmission is basically regulated @ 60 PSI plus or minus 2.5 psi. Regulator will be on back upper right corner of transmission. Low air pressure or leaking o-rings will effect range shifts. I have leakdown setup I made so I can check pressure and leakdown test on range piston. Fuller has service manual for troubleshooting air system on transmission on roadranger.com
    Goodysnap Thanks this.
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Thank you both. Next weekend or if I have another day off this week from rain, I will check air pressure and report back to this thread and let you know what I find. Thank you
  4. 062
    062 Road Train Member
    6,291
    33,837
    Oct 20, 2013
    Is the problem worse when trans is cold?
    I have a eaton reman,at about 300k it started being slow when cold,by 350k it stuck in low.
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Seems to be consistent whether it’s hot or cold
