Eaton 6 synchro - grinds going in reverse
Discussion in 'Trucks [ Eighteen Wheelers ]' started by montrose818, Jul 12, 2019.
  1. montrose818
    montrose818 Light Load Member
    90
    36
    Apr 9, 2018
    Hey guys, question on a truck
    Its a synchro 6, so no clutch brake
    I can feel the gears moving going into reverse with the clutch all the way at the floot, even after waiting several seconds
    A shop suggested clutch needs adjustment, but I have about 1.5" of free play. Either way its not a slipping issue, but seems like it doesnt release all the way?
    Any pointers?
    I just had the trans changed by a shop but they said they didnt touch the clutch
    Much appreciated. Thanks
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,537
    9,875
    Mar 30, 2014
    Reverse doesn't have synchro. So if it doesn't stop, put it in a forward gear, which will stop the gears, then you should be able to put in go backwards.
    Hulld and daf105paccar Thank this.
  4. montrose818
    90
    36
    Apr 9, 2018
    Thanks but I need to fix this not work around, I have different people behind the wheel and cant trust them to do this everytime, they will just end up jamming it in..
  5. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    That is NOT a workaround.
    With a syncro gearbox correct procedure is to put truck in first gear and then reverse.
    Hulld, spsauerland and Bean Jr. Thank this.
  6. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    You could have an issue with the pilot bearing in the end of the crankshaft going bad.
    spsauerland Thanks this.
  7. montrose818
    90
    36
    Apr 9, 2018
    Not arguing with you, but Eaton document doesnt mention this at all
    https://www.google.com/url?sa=t&sou...FjAEegQIBhAC&usg=AOvVaw3ov0-TNxNJqJMQFXbjujlG
    I understand what youre saying and have read that suggested prior to asking on here, it just doesnt seem right because if a driver doesnt do this, damage is likely to occur. Its a synchro, so obviously shifting skill is not part of driver knowledge like on a 10+
    Might call Eaton and ask
    daf105paccar Thanks this.
  8. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    No matter who makes a synchronized transmission there is absolutely no synchro for reverse.
    This is because in a single transmission application you always come to a complete stop going from forward to reverse or vise versa.
    If you are having trouble engaging reverse the only problems that I have seen cause this is the pilot bearing going bad and seizing to the input shaft causing the input shaft to spin with the the clutch in.
    The other cause I have seen is a broken clutch disc spring falls down between the clutch disc and the pressure plate wedging there causing the clutch to drag so the shaft continues to spin even though the clutch is in.
    spsauerland, Bean Jr. and Heavyd Thank this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Moral of story... If transmission is out always replace clutch and inspect/replace related components.
    pushbroom and Hulld Thank this.
  10. montrose818
    90
    36
    Apr 9, 2018
    wasnt my call, I would have thought they did, but found our after the fact they didnt. Thats why I am trying to gather info before heading down there.
    The trans they installed had a bent input shaft they told me, and replaced it with another (used) one, so I am now understanding how this works, with your help. Thanks all, I have somethibf to go off mowm
