Eaton automatic transmission shifting hard
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Misterpreston, Jun 16, 2017.
  1. Misterpreston
    Misterpreston Light Load Member
    96
    4
    Mar 24, 2016
    I've got an Eaton advantage plus automatic transmission. As of late when I go into drive and it goes into 2nd gear it puts it in gear hard and when I got the gas it kinda bogs down a bit than jerks and gets into gear. It's shifting fine on all the other gears well it does the same thing into reverse as well. I've had the 2 zerks greased as well recently. Had the fluid changed as well about a month back.
  3. Misterpreston
    96
    4
    Mar 24, 2016
    Also it shifts harder at the end of the day going into second at start up
  4. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    And did you analyse a oilsample when you changed the oil?
  5. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Quit eating beans.....or stop putting 'gas' in a diesel engine?
  6. Misterpreston
    96
    4
    Mar 24, 2016
    No i did not.
  7. Misterpreston
    96
    4
    Mar 24, 2016
    Autocorrect I ment to say when I push the gas. If that's better for you.
  8. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    I do not have to tell you that you need to change.
    Start doing oilanalyses.
