Eaton fuller 10 speed manual split box valve gets stuck.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mickutzu2011, Sep 27, 2021.
  1. mickutzu2011
    mickutzu2011 Bobtail Member
    16
    I have an manual 10 speed transmission and when I don't use it for more than couple a days the split box valve gets stuck. After a lot of down and up shifting the spliter is working. Does anyone knows what the problem?
  3. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    I'm sure that someone who's an expert will chime in soon enough but my own idea would be the filter regulator or the slave cylinder itself.
    beastr123 and Big Road Skateboard Thank this.
  4. Big Road Skateboard
    6,307
    34,989
    May 2, 2021
    Probably dry piston seals on the piston, depending on year and model.
  5. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Change the handle 70$
  6. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    So You are missing the shifts then when going from lo-high or high -lo? Or is this just you fiddling with it in neutral and not moving when you arent supposed to do do that?
  7. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    What model transmission? Probably need range cylinder kit and clean real good. Plus make sure contaminants are not getting into your air system.
  8. mickutzu2011
    16
    When it's cold it shifts 1 thru 5. When I try to go hi on 6 doesn't work. Them I flip the hi-low switch until I hear that click down in the the transmission and it works just fine after
  9. mickutzu2011
    16
    I really don't know the transmission model. I know that is a eaton fuller 10 speed
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Before I bought a kit i’d try just changing the air filter. You only have to drop a couple psi inlet pressure at the shift solenoid before it won’t shift right. New filter may cure it.
