Eaton/Fuller 10 speed sloppy gear pattern
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jmillwood, Feb 19, 2011.
  1. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    depends on what all they find wrong with it but plan on at least a couple thousand with removal and installation.
  3. k whopper
    k whopper Light Load Member
    100
    13
    Sep 9, 2011
    milledgeville ga
    whats the difference in a 15210c fuller and 16210c fuller and are all top plates the same on a fuller the reason im asking is the 16 came out of my w9 and the 15 was in a international and my shop is saying the gear shif is touching a cross member with the 15210c in reverse 2nd 4th put the top plate on off the 16 and it fine the my old top plate is worn and had to hold it in reverse and 2nd and 4th
  4. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    No, they aren't all the same, some have what they call "forward control" and your 16210c must be a forward control and the 15210c is not a forward control.
  5. k whopper
    100
    13
    Sep 9, 2011
    milledgeville ga
    thanks bender i will get my old plate redone
    bender Thanks this.
  6. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    get a backwards plate than you can throw it to the dash for tenth....
  7. Aditransport
    Aditransport Light Load Member
    111
    21
    May 19, 2012
    Colorado Springs, CO
    My gear shift makes a crackling like noise when I'm pulling a hill and getting on it. I have the Eaton 10 spd. It does it mainly in 8th, 9th and 10th. Seems to be worse the lower the rpm gets. I can hold the shifter steady with my hand and the noise is almost gone. Could there be something wrong in the trans or do i have the same problem with bushings and such?
