Eaton fuller 10spd. High gears not staying engaged
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ryantcastro92, May 23, 2022.
  1. ryantcastro92
    ryantcastro92 Bobtail Member
    Hello fellas, I'm new to this thread. My issue is with an Eaton Fuller 10 speed. It shifts perfectly; from reverse to 5th gear, but as soon as I shift to high gear (6th), it does not shift. All high gears feel like they slip
  3. jamespmack
    216,135
    RT,RTO or FRO trans model?
  4. MadScientist
    MadScientist Light Load Member
    99
    144
    Dec 14, 2019
    Or RTL(O) "Super 10"?
  5. Big Road Skateboard
    6,481
    36,294
    May 2, 2021
    Probably synchro slider not going into aux drive gear, likely due to a broken synchro pin. Use shop air and operate it that way.
    If still no high, it's probably got to come apart
    Bean Jr. Thanks this.
  6. jamespmack
    216,135
    Still a RT trans.
    Fro would most likely be snap ring on shaft. And yes the inner one under top plate.
    But no sense in diagnosis with no model.
    Eaton Service ranger is a good website.
    Bean Jr., Oxbow, spsauerland and 2 others Thank this.
