I have air leaking from this part on the transmission. I took it off and the gasket is bad. However I have been looking through the parts diagram and can't seem to find what this part is called.
Closest dealer is over an hour away and I want to make sure they have it first.
Eaton Fuller 13 Speed - Need help identifying part
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HDFatboy, Mar 13, 2015.
That the range valve I believe.
It cycles when you go from low to high range.HDFatboy Thanks this. -
It looks like the oring on that shaft is leaking letting oil into the air cylinder. You "can" change it without taking the rear case off, but it is harry. You need to make sure you dont lose where the shift fork rides on.
When I get a chance I will take the cover off again and inspect it. -
Good deal. I wish everyone finished their threads like this. It helps anyone coming in behind you.
puncher Thanks this. -
