My truck had the 13 rebuilt maybe 15-20k miles back and already seems to be developing something of a growl. I've checked the oil and it's full, beyond that I don't know what else I should be looking at. What service should I be doing on the trans and at what intervals?
Not a mechanic but have a good amount of mechanical aptitude and any tool I could possibly ever need. Thanks in advance.
Eaton Fuller 13sp growling issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Mar 6, 2011.
you can pop your bottom plug--dont drop the oil---and see if there are any chunks on the magnet
if thjere are peices --you might want to drain it--and try synthetic---not sure if it will help--maybe get the guy who rebuilt to have a listen -
What exactly is it that I should be checking for as far as the ride height goes on the air ride? I know that my bags are airing up, beyond that I wouldn't know what to look for.
Have the trans oil analyzed?
If there is chunks on the magnet it's too late, don't bother with the synth, find another trans. -
In my older truck i had a RTO 12513, when it got rebuilt they put 50wt oil in which it recommended. I had use 90wt gear oil in the past, so with the thinner oil it would be alot more noisey, it ran great and shifted well but noisey
Wildcat74 Thanks this. -
pull the plugs in both rears also, the noise will follow the drive line and sound like tranns and be rears.
