Hi Fellas, i need to change the clutch brake and need to know if a 9 speed eaton has a 2 inch or 1 3/4 input shaft so i can order a 2 piece brake any help as always is appreciated thanks.
Eaton Fuller 9 speed input shaft help? (clutch brake)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jsnap, Apr 30, 2009.
depends it could be 1.5 1.75 or 2.0 you will have to pull it to find out
should be a 2 inch.. do u know model number on trans
No i dont i just thought certain speed tranies had the same size shafts . Percentage wise what would you say it has a 2inch shaft
i will almost guarantee its a 2 inch shaft
jsnap Thanks this. -
good enough for me ill buy it
