Eaton Fuller automatic transmission with a clutch looking to change to manual 10 spee
Discussion in 'Volvo Forum' started by SBdizel, Jan 19, 2015.
  1. SBdizel
    SBdizel Bobtail Member
    10
    I know that these conversion have been done as long as you have clutch pedal. Has anyone done this conversion and is willing to share with me what he did with the range valve and how to dissable the neutral switch and get rid of the transmission computer???
  3. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    It was done to my truck. 10 speed auto shift with clutch pedal was converted to manual. Payed $2000. There is mechanic in chicago area who is very good at this.
    SBdizel Thanks this.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    You will need to change the Top Plate and Shifter to a Manual 10 Speed. The Neutral Safety Switch and Computer need to be rewired correctly or you will burn up the transmission. if you are in California there is a Mechanic I know that has done dozens of conversions for around $1500.
  5. Balactransport
    Balactransport Bobtail Member
    5
    Chicago, IL
    I am located in chicago can you pleasse give me the name or fone number of this mechanic in chicago
  6. SBdizel
    10
    Pleasse give me more information on the mechanic in the chicago land area that does these conversions thank you.
  7. simon999
    240
    95
    Feb 6, 2014
  8. Osmani96
    Osmani96 Bobtail Member
    What is the name or location of the shop in CA??
  9. The_Truckr
    The_Truckr Bobtail Member
    7
    Sep 30, 2011
    Artesia,CA
    Is this shop still in business??
  10. boneebone
    2,297
    2,371
    Mar 13, 2009
    No, the shop is no longer in business.
    What area do you live around, I may know or can help you find a shop that does conversions?
  11. MooneyBravo
    MooneyBravo Heavy Load Member
    856
    1,224
    Feb 20, 2012
    Vermilion, Oh
    Educate me here. What is the reasoning and benefit of making this change? That truck was engineered to operate with an autoshift transmission. I've shifted pretty much every transmission there is in nearly 40 yrs. I can use mine as an auto or manual by simply pushing 1 button.
