Eaton fuller drain plug stuck, will my impact work to remove it?
Discussion in 'Freightliner Forum' started by Dorego401, Mar 10, 2021.
  1. Dorego401
    Dorego401 Bobtail Member
    31
    5
    Oct 11, 2020
    Hey guys I got the fill plug out will my impact gun but having a hard time with drain plug . Any suggestions? Plug is also starting to lose its 1/2 size (stripping slowly)
  3. AModelCat
    161,657
    Smack it with a hammer flat on the face once or twice. Shock tends to loosen them up.
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Or weld a nut to it.
  5. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Should be two drain plugs on it. On mine, I can't get the lowest one out, but the other one gets 95% of the fluid drained. You really need some actual square drive sockets. (so do I) If shocking it with a hammer doesn't work, take the cradle off your floor jack, and jack up against your breaker bar so it stops trying to cam out of the plug. Might give you the edge you need.
  6. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    Try using the right size wrench or an adjustable with a Long pipe.
    Just make sure you are completely on it, do not hurt yourself.
