eaton fuller rto 9513 air lines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 76K100, Mar 27, 2023.
  1. 76K100
    76K100 Light Load Member
    55
    89
    Mar 13, 2023
    WISCONSIN BUT FROM NOR CAL
    So I bought the 5/16 line upgrade kit for my 13 speed and they are that rubber silicone type and was wondering if anybody has issues with the push to connect fittings leaking air at the shifter line connection and what's your opinions on the rubber type lines? Are there a should use type of line versus another type? thanks again
  3. Big Road Skateboard
    6,189
    33,984
    May 2, 2021
    5/16", or 5/32"?
    Plastic is normal for splitter and range cyl, but could have rubber on older trucks. Can you post a pic?
