Eaton Fuller "slips" under a load
Discussion in 'Freightliner Forum' started by Opus, Apr 11, 2014.
  1. Opus
    115,719
    Freightliner Cascadia
    500,000 miles
    Eaton Fuller 13 Speed
    Recently, when under a load, when it starts to lug down a bit, it acts like I just ran over a patch of ice......tach reves about 2-300 rpm and then catches. Or if I try to use too much throttle while accelerating.
    That's the best way I can describe it.......if you've ever ran over a random patch of ice on an otherwise clear road, you'll know what I mean
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,340
    7,625
    Jul 11, 2012
    in the bush somewhere
    Sounds like your clutch is slipping.
  4. passingthru69
    clutch adjustment time.. I agree
  5. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    Defiantly my old company truck, needs more clutch brake.
  6. Opus
    115,719
    Hi Ho Cairo from just up the street in Albany!!
    So, is this a $400-$600 deal, or is it a catastrophic $10,000 major rebuild?
    How long do I have? Am under a 20k load at the moment going to Quincy, the a 20k load to Columbia SC. I was thinking that booking a 44k load that goes over Jellico or Black Mountain would be a mistake. But, could I book something out of Columbia going to a good shop in Atlanta or Nashville or even Columbia??
    Any suggestions on a shop in the southeast would be helpful as well
    Thanks to all who helped.....
  7. rbrtwbstr
    3,340
    7,625
    Jul 11, 2012
    You can have the adjustment done at most truck shops. Shouldn't take more than half an hour. Until then, avoid the heavy loads and big hills as best you can. When it begins slipping, let off the throttle slightly, until the slipping stops. You may have to shift down a few gears extra
  8. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Get clutch ADJ. ASAP!! ck for fuel leak on return lines at back of head small leak will do that
    wore out Thanks this.
  9. bad-luck
    bad-luck Road Train Member
    3,259
    5,973
    Nov 16, 2013
    Baltimore, Maryland
    sounds like the clutch is slipping maybe time for an adjustment or time for a new clutch
  10. bad-luck
    3,259
    5,973
    Nov 16, 2013
    Baltimore, Maryland
    generally a clutch adjustment they usually charge about an hour laboryou can have that done just about at any truck shop. Worst case scenario if you need a new clutch the clutch itself is about a thousand bucks and it's about a 10 hour in labor job
  11. wore out
    wore out Numbered Classic
    15,416
    186,073
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If its a hood with a 15 1/2 9 spring plate which is most expensive clutch we get 2000.00 turn key at my shop which includes turning flywheel and thru shaft bushings. If its something like a columbia or volvo it goes up from there. I'm not trying to hustle up business just trying to give you a real world figure. BAHA hit it straight on the head with adjustment and fuel lines asap
    Just read the truck specs lol some where between 2250 and 2500 if adjustment won't cure it. Should take a day to day and a half at most.
