Eaton RP461 axle shaft won't come out- help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by upstate81, Oct 30, 2018.
  1. upstate81
    upstate81 Bobtail Member
    14
    6
    Oct 30, 2018
    Newbie to your site- hello all.
    I have a 1988 Int. Paystar 5000 tandem dump, ex municipal truck heavy specs. Bolt on the bottom of the rear rear came out and lost all fluid, rear got hot. I replaced the bolt tightened everything, refilled gear oil and hoped for the best, did not go so well. The rear was shot, went to pull the axles one came right out and the other came out about 1" and that was it. I have put a 15 ton puller on it, hooked it to my excavator and tied it off to the my dozer and that axle won't come out. I am guessing that a gear or bearing has seized on the shaft and will not allow it to come out. Anybody have a problem like this, looking for any suggestions beyond getting a different truck.
  3. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Just curious, this rear isnt a locker is it?
    Oxbow, SAR and blairandgretchen Thank this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    We usually take a long rod and stick through the other axle hole and beat it out from the other side of truck. Just make sure no one is watching the axle on the other side. Back in the 60s my dad knew a guy that did that and it knocked him out.
    Oxbow and swaan Thank this.
  5. upstate81
    14
    6
    Oct 30, 2018
    h
    yes I think it is a locker
  6. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    I've have seen some where the splines section of the axle shaft where the splines lock up gear bound on the axle shaft
    SAR Thanks this.
  7. upstate81
    14
    6
    Oct 30, 2018
    thanks for the help I took your advise and got a BFH and went to town on the axle. I had to buy a 2" x 5' solid steel rod put it through the other side and with my excavator hooked to the axle beat on that shaft for about an hour and it was out. It was badly damaged where it was hanging up on the end of the spline where it passed through the sun gear slider. So now that it is out I am looking for a used rear Eaton RP461. The ring and pinion were ok, other than having gotten hot, but the internals of the planetary were shot. thanks again.
    Smellfunny Thanks this.
  8. upstate81
    14
    6
    Oct 30, 2018
    the gear that contacts the spider gears slide fine, it was hung up on damage to the sun gear slider, this was only used on this two speed rear, and it was set up to be locked in low. not sure why that was put on a tandem but apparently it was somewhat common on the heavy spec trucks.
