Eaton transmission installation with hydraulic release fork
Discussion in 'Freightliner Forum' started by GoatHorns, Aug 13, 2014.
  1. GoatHorns
    GoatHorns Bobtail Member
    What's up guys. I'm working on installing a trans in a Cascadia. I couldn't remove it without also removing the clutch at the same time, and I installed a new clutch, pilot bearing, release fork and am putting a brand new trans in. I have about 1" left to go, and am getting hung up on something, it looks like the hydraulic release fork (which mounts at the bottom of the housing) is getting wedged between the bearing and the clutch. There's no room for it. Any tips?
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Might have to move the arm up to slide behind throw out fork before sliding trans. tight.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    there are three different styles of hydrolic release fork used by eaton.
    With straigt fork on ball (MAN trucks, cylinder on left side of transmission), fork with servocylinder on bottom of bellhousing (Volvo) and cylinder on top.
    bellhousings and all clutch parts are totally different.
    So can u post a picture of your front end of transmission
