Eaton Ultrashift intermittently Jumping when put in D or R
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Alexp2686, Oct 23, 2023.
  1. Alexp2686
    Alexp2686 Light Load Member
    69
    36
    Jun 10, 2020
    Eaton Ultrashift intermittently Jumping when put in D or R also sometime when I accelerate. and by intermittently, I mean sometimes it goes 800 - 1500 miles without doing it then Idk if it's just a coincidence Ill hit a small pothole or park on an incline and as soon as it goes into drive my cab will shake violently and it feels like the truck is trying to take off at high speeds.
    ive noticed when this happens everything is faster when i accelerate it'll pull a 35k load like I'm empty when it usually takes half an rpm to start moving..
    I just had clutch replaced, my inertia brake was broken and also replaced the actuator, and im still getting this issue.
    if anyone has any idea please let me know because every shop Ive called is giving me a different answer so im not sure who to go with. my personal mechanic said to replace all the transmission sensors, another shop said its the computer.
  3. JB7
    JB7 Heavy Load Member
    952
    1,642
    Dec 13, 2022
    Laurel, MD
    It's not a guessing game. Are there any active or historical codes? Use internet to search for "Eaton Fault Code retrieval". Has anyone used any diagnostic procedures? "....Ill hit a small pothole or park on an incline..." This sounds like there is a loose/corroded connection or where a wire is exposed due to the insulation being rubbed through.
    Eaton IntelliConnect is included with every Eaton and Eaton Cummins automated transmission. Our vehicle system experts create comprehensive fault code action plans beyond just reading transmission fault codes. Using a holistic systems approach, we look at data from other vehicle components to determine potential root causes and solutions.
    There is a fee involved. You should contact Eaton as an option.
    Alexp2686 Thanks this.
  4. Alexp2686
    69
    36
    Jun 10, 2020
    I took it to 3 Dealerships they didin't mention any codes. I have my friend coming over to plug in his computer today I'll let you know if they see any codes.
    The shops that looked at it were: JX truck center in Illinois Ruck truck in Texas, Jacksonville and a Kenworth in Jacksonville FL. the one in Illinois replaced my Actuator, Texas Reprogramed and Jacksonville Rush Replaced Clutch because my inertia brake was broken, Kenworth had Reprogrammed saying sometimes the computer didint take the first reprograming. So I figured I'd come here and try my luck, but the connection part does seem like a possibility. where are you located? and what would I be looking at for a DIAG like that? feel free to PM me if you dont want to post it.
  5. DixonM
    DixonM Medium Load Member
    372
    782
    May 22, 2022
    I drive one with issues also and no one can figure it out. New clutch put in and reprogrammed multiple times took video of dash lit up but never any codes
  6. JB7
    952
    1,642
    Dec 13, 2022
    Laurel, MD
    Did anyone contact Roadranger support? +1-800-826-4357
    Ultrashift Plus (possibly other models) have a Snapshot feature that a driver can initiate.
    Snapshot is a diagnostic procedure used to capture specific data at the time an event is happening. This data should be collected and reviewed at the direction of Eaton technical support.
    For some issues reprogramming alone not enough. Eaton has a procedure to install an earlier software version, disconnect batteries for 5 minutes, reconnect and then program the latest version.
  7. DixonM
    372
    782
    May 22, 2022
    I bring the truck to the shop once a month for them to do their thing never been given any direction on the procedure you speak of but at the shop we have a technician that works for Rush and he is the one doing the majority of the work. I drive a smooth bore tanker and we supposedly have a time to help with the liquid movement.
  8. DixonM
    372
    782
    May 22, 2022
    Time should be tune sorry
  9. GatorCrusher
    GatorCrusher Bobtail Member
    Did you ever find a fix for this issue? I’ve had the same problem and nobody has been able to fix it.
