Ecm doesn't match
Discussion in 'Ask An Owner Operator' started by JORTRUCK, Jul 14, 2017.
  1. JORTRUCK
    JORTRUCK Light Load Member
    232
    31
    Mar 9, 2017
    ECM doesn't match with odometer
    ECM k503 and the odometer k401
    So what the right number for the
    Mileage ???
  3. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    Something was changed ecm is what I would go with because it is know that people can and do revised the odometer to make it look as it has lower miles
    Grubby Thanks this.
  4. JORTRUCK
    232
    31
    Mar 9, 2017
    Can someone change the ECM from high number to low number
  5. Grubby
    Grubby Road Train Member
    2,475
    135,505
    Aug 30, 2016
    Fostoria Ohio
    Dont brand new ECM's start out at 0? Im positive they do.
  6. AModelCat
    162,194
    I would assume mileage to be the higher of the 2.
    dunchues and Grubby Thank this.
  7. kemosabi49
    10,917
    47,423
    Jan 13, 2013
    SW Arkansas
    If you had a new ECM installed wouldn't it have the lower milage? Don't see how it would pass the odometer. I think the ECM is probably correct.
    Grubby Thanks this.
  8. Grubby
    2,475
    135,505
    Aug 30, 2016
    Fostoria Ohio
    What I meant, say the truck has 3xx, xxx miles and the ecm gets replaced, the new replacement ecm would start at 0 .
  9. JORTRUCK
    232
    31
    Mar 9, 2017
    What about if replaced both ECM and
    odometer . Noway to know the real number for mileage ???
    Bascomd Thanks this.
