EDL Requirements for 2009 Truck - New Driver
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by animalfriend, Nov 12, 2024.
  1. animalfriend
    animalfriend Bobtail Member
    We're looking to purchase our first truck. My partner had a CDL years ago and is getting his license again. He already found a truck he likes: a 2009 Western Star. From what I read, EDL are required for trucks newer than 2000 unless they have an older engine. The one he wants to buy has a Detroit 60 that was manufactured in 2018 (per sticker on engine).
    It does not currently have EDL. The seller said the truck isn't set up for them and therefore, they're not required. This contradicts what I've read. My question is if there could be a scenario that such a vehicle would not be required to have EDL. And if they are required, what would be the cost to comply?
    Thank you in advance for any info that can be provided.
  3. drothman
    drothman Bobtail Member
    Re the cost to comply, there are many ELD solution providers you could check with, including HOS247, Smart ELDs, TT ELD, Blue Star ELD, and many more.
    As for whether it's required, per https://www.fmcsa.dot.gov/hours-service/elds/general-information-about-eld-rule it seems so:
    Q3. Who must comply with the electronic logging device (ELD) rule?
    A3. The ELD applies to most motor carriers and drivers who are currently required to maintain records of duty status (RODS) per Part 395, 49 CFR 395.8(a). The rule applies to commercial buses as well as trucks, and to Canada- and Mexico-domiciled drivers.
    The ELD rule allows limited exceptions to the ELD mandate, including:
    • Drivers who operate under the short-haul exceptions may continue using timecards; they are not required to keep RODS and will not be required to use ELDs.
    • Drivers who use paper RODS for not more than 8 days out of every 30-day period.
    • Drivers who conduct drive-away-tow-away operations, in which the vehicle being driven is the commodity being delivered.
    • Drivers of vehicles manufactured before 2000.
    flood Thanks this.
  4. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    The seller is wrong... that truck is required to use a eld and yes it is setup for one..
    The truck has an electronically (computer) controlled engine and eld's use the plug-in diagnostic port in the dash.
    Cost will be $200-$800 depending on brand. If you have the right rand mcnally GPS they make a add on eld that plugs in the truck and uses the GPS for the eld
    Bean Jr. Thanks this.
  5. Big Road Skateboard
    6,162
    33,777
    May 2, 2021
    Well, the truck doesn't have a 60 Series manufactured in 2018. That is for certain.
    Are you certain that's not a remanufactured date, or maybe not even a 60?
    ‘Olhand Thanks this.
  6. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,692
    16,267
    Jan 18, 2011
    If it’s actually exempt and he should provide paperwork Then it would have an early DDEC manufactured in the 90s and rebuilt
  7. animalfriend
    Thank you all for your input. I'm completely new to this and appreciate you taking your time to reply. My partner has more knowledge, but has been out of the loop for a while. The seller said it was a new Detroit 60 engine. I had taken a picture of the label and just looked at it. Big Road Skateboard was right... the label says Detroit Diesel Remanufacturing East.
  8. flood
    4,161
    4,031
    Dec 25, 2010
    Unless the truck was ordered as a glider it is illegal to put an older engine in it
    FLHT and kemosabi49 Thank this.
  9. themetro
    themetro Bobtail Member
    43
    53
    Sep 30, 2018
    Can you cite the relevant regulation on that?
    I'd like to look into building a glider. To avoid the ELD requirement, primarily, but also to get away from as much of the late model, potentially trouble-prone, high tech gadgetry as possible. (No, I'm not looking for means to violate the HOS; I just don't like being compelled to pay for a service, nor the privacy intrusion.)
    I'm seeing some very late model units offered for ridiculously low prices. And salivating at the thought.
  10. FLHT
    FLHT Road Train Member
    1,381
    2,405
    Aug 2, 2014
    A couple of O/Os here were in need of rebuilds.
    They went and bought older motors and overhauled them with the same idea you have.
    They run great without all that emission stuff.
    The company will not lease them back on without an ELD.
    In fact the company's requiring an ELD on every truck they lease on.
    themetro Thanks this.
  11. FLHT
    1,381
    2,405
    Aug 2, 2014
    Myself have a 2018 pete with emissions and its got issues. $$$
