EGR actuator leaking antifreeze from metal hose
Discussion in 'Freightliner Forum' started by ktrucking, Dec 12, 2018.
  1. ktrucking
    ktrucking Bobtail Member
    8
    I have a 2013 Cascadia DD 15 EGR actuator leaking antifreeze from the metal hose coming from the actuator going into the engine I replaced the part 3 times part# A47220000151 does anybody knows why or where is causing the back pressure is coming from or do I need to buy a new actuator that can be the problem? No lights on
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Just buy a new updated kit for egr actuator comes with pipes and fitting replace and should be all good.
    msh Thanks this.
  4. ktrucking
    8
    I was told to flash the coolant first to see if that solves the issue I was going to try that before I spent $1300-$1600 For a metal hose issue where the EGR actuator is not a problem to see if that fixes the back pressure problem if not definitely will take that Under advisement thanks just trying to see if anybody else has the same issue
  5. QUALITYTRUCK
    1,804
    1,765
    Jun 14, 2009
    romulus,mi
    flash the coolant?????? EDIT: Sorry, I think that you meant flush.
    msh Thanks this.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    are you sure metal hose is leaking and not the adapter that goes between metal hose and actuator body ? there is a o ring that goes between actuator body and connector adapter.
  7. 3141 crestveil
    3141 crestveil Bobtail Member
  8. 3141 crestveil
    Add a radiator stop leak it will stop. Works good in the summer never leaks until winter. It leaking inside your egr. There's like a small heater coil inside that's leaks when it goes bad.
  9. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    there is no heater coil inside. I have opened them. if you will open upper or lower covers you will see the coolant flows through body..
  10. 4noReason
    4noReason Road Train Member
    2,377
    731
    Nov 29, 2012
    ya mine leaked too. they changed o rings and i was good to go
