EGR Cooler
Discussion in 'Volvo Forum' started by d281833, Feb 14, 2013.
  1. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    So, 2012 780 D13 61,000 miles. Get a 4752 code that is EGR Cooling Efficiency. Replaced sensor, flashed the ECM and fixed. 400 miles down the road code appears again and lo and behold it needs an EGR Cooler. They told me that it was plugged. Plugged?? Did I mention 61,000 miles? What kind of crap are building nowadays? Not looking forward to the next 61,000.
    scottied67 Thanks this.
  3. FozzyNOK
    FozzyNOK Road Train Member
    2,478
    3,820
    Jul 18, 2007
    Oklahomistan
    Depends on whether or not there is something leaking into the EGR system.. we had a coolant leak into the EGR system on one truck and it took out the entire EGR system and the DPF filter... turned the PDF from crystal / solid into mud.. plugged the entire exhaust system..
  4. Volvomack
    Volvomack Bobtail Member
    Just had same problem they cleaned out two tubes going to EGR with a coat hanger and this is the important part reflashed the computer to widen out the peramiturs
  5. frito-bandito
    frito-bandito Bobtail Member
    7
    Inman, SC
    If there is any coolant leaking internally, it will mess things up fast...especially DPFs, don't feel bad, we have DD13s and 15s with less than 20K having those problems.
