EGR probe for each cylinder?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ModZZilla, Nov 6, 2013.
  1. ModZZilla
    ModZZilla Bobtail Member
    17
    8
    Sep 22, 2013
    I have a C-15 that I would like to monitor temps of each cylinder. I'm thinking that way I could find a bad injector. Cut out test isn't working. Could I drill manifold at each port and install 6 probes. Like I have done on my snowmobile. Anybody ever do this?
  3. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    It would probably be easier to get an infarred temp gun, run the engine to operating temp and check each cylinder with the temp gun.
    baha Thanks this.
  4. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Im sure someone has done it. I've often thought about doing it and using a data logger to monitor what is happening in each cylinder under different engine loads.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    You can do a cylinder cut out test down to one cylinder on a Cat.
    I have tried using an infered temp gun on a running engine it does not work to much heat transfer. Using water in a spray bottle works better but not good. Removing the manifold , and running it works, some injectors will work 95% of the time, at lower output and a cylinder cut out test checks them a a higher delivery rate. I would do a complete valve set and check every conection on the injectors, and actuators, looking for loose wires, loose conections, and wires worn, usually a tie strap will be broken alowing the harness in that area to come down.
    Drilling holes in the manifold is an expencive idea, the old manifolds, "A" & "B"s, some came with 1/4 inch pipe plugs below every port.
    Just a thought!
  6. ModZZilla
    17
    8
    Sep 22, 2013
    Heat soaked manifold would not be accurate enough.
  7. ModZZilla
    17
    8
    Sep 22, 2013
    OK, Here's the deal, Fabco (local Cat dealer) just did me a platinum in frame. Truck smokes white (raw fuel smell) like crazy when cold. I took it back, they did all the cut out test. They say it all checks out. It's not even safe to follow for 1/4 mile, till smoke clears. When warm it runs good and no smoke. It's MBN bridge motor, and it didn't smoke with the old injector. I wanted them to pull the new injectors and test them, but they have to send them out for test and refuse to do all 6.
  8. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    They (Fabco) obviously does not have the ability or desire to fix it correctly, your "Platinum" rebuild has a nation wide warranty, I would find one that does. Just because it says Cat on their building and shirts doesn't mean they are an expert at anything.(except emptying your wallet)
  9. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    White smoke when cold is WHY I did an inframe on my MBN lol!! Turned out the head gasket was gone on #4. It never pushed any coolant, and passed all the cylinder cut-out tests when warm. Once my engine was warm it didn't smoke either.
    I wonder if they got all the protrusion heights correct?
    Bill
