EGR valve question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by God prefers Diesels, Dec 18, 2020.
  1. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    CM870. If you open the "door" on the EGR valve, and let the arm pop out some, and then push the arm back down (not knowing if everything is in the same position as before), will you need Insite? Or can it move the arm back and forth, and relearn it's own endpoints? Not sure if I'm explaining it correctly, but people that know the answer will probably get the gist of what I'm asking. I'm talking about the big piece that goes into the positioning sensor, and connects to the valve with a master chain link.
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Bump....
    Sorry GpD, no first hand experience. #### yellow 2WS got neglected with 'em extra parts. :occasion5:
    God prefers Diesels Thanks this.
  4. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    Well, I guess it's going to need Insite. Throwing a code PID-27 FMI 4 "Percent Exhaust Gas Recirculation Valve #1 Position"
  5. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Valve doesnt need relearning on insite. It has a motor which does what the ecm tells it to and a sensor that verifies valve position.
  6. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    I don't have a way to scan it. The code that I can see is PID-27 FMI 4. In my KeepTruckin dashboard, it says: "Percent Exhaust Gas Recirculation Valve #1 Position". But in the truck on the Road Relay, it says: "Voltage<Normal".
    Would you say the valve is bad? And for the sake of argument, if I refuse to replace it, what's the next step? Can it be ignored, or will it silent derate? Between me and you, the valve isn't leaking, I'm sure of that...
    062 and black_dog106 Thank this.
  7. 062
    062 Road Train Member
    6,217
    33,469
    Oct 20, 2013
    I ran with it “stuck” closed for 2-3 months until I got it “fixed” permanently. You’ll have a CIL and slight derate,but I couldn’t tell any difference in power.
  8. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    I don't have a light, just a code. I'll tell you what I did, and @MACK E-6 can clean the post up if I cross a line.
    I opened up the valve mechanism. I saw the motor spins a large gear, which spins the arm that moves the valve up and down. That arm is connected to an axle that goes into the positioning sensor. The arm is held in place by the valve itself. So the valve needs to be in the valve guide, or the arm will gradually pop out, and start rubbing the inside of the case. So I took the valve out, and cut the top of it off with a die grinder. Then to make sure the valve rod had plenty of clearance to move up and down, I took the top of the valve, flipped it upside down, and glued it to the top if the EGR valve with some JB Weld Extreme Heat. Then, I cut a 2 1/8" piece of thin steel and blocked off the side that goes to the EGR cooler. I took a piece of that green flexible brake tubing, 0.25" OD, and used that to make a custom coolant line to bypass the EGR valve. Can you picture everything I'm talking about?
    So in theory, the computer should think the EGR valve is still functioning from a mechanical perspective.
    Edit: I did all this, because I was getting turbo bark at full throttle. I unplugged the motor in October, and the bark went away. But I've got low boost. (always did since I bought the truck) So I figured some might be bypassing the valve. Truck runs sustained 20.6 psi. It will spike to 30 psi, but gradually fall back to 20.6 psi on a sustained pull.
    black_dog106 Thanks this.
  9. Inderjit
    Inderjit Heavy Load Member
    723
    708
    Sep 17, 2017
    If the engine warning light is not on then the code is most likely inactive or historical.
    If you have the software and a communication adapter you should be able to clear it.
  10. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    It's a new code. My Road Relay was able to clear all the old ones, but it just beeps when I try to clear this one. Can that code cause a silent derate? My boost is better. Sustaining about 29psi now. But lots of times it seems really RPM dependant if that makes sense. Like the VGT just works when it feels like it.
  11. pushbroom
    1,779
    7,313
    Sep 1, 2012
    This should be your code i think.
    Ecm checks egr valve position by using the egr differential pressure sensor to verify flow. You are lucky it is an older engine and not as sensitive to tampering as the new ones are.
