Egt temperature sensor
Discussion in 'Ask An Owner Operator' started by pavrom, May 15, 2022.
  1. pavrom
    pavrom Road Train Member
    3,203
    7,358
    Apr 29, 2012
    NE illinois
    Can anyone share a link pls . I have oem pre 2007 2" pyrometer and need egt temp sensor to complete set up . I see them on ebay all the way from $10 to $200 , would like someone's feedback on the one you purchased .
    Thank you
  3. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    It's called a stinger, you need 1 that's compatible with whatever brand your gauge is. They come straight or in a 90 degree depending on how it's mounted in your exhaust
  4. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    I always bought them as kits that includes the gauge and thermocouple. Isspro, Autometer, etc. Thing is, IDK if you can mix and match because if the ohms aren't right, the gauge won't be accurate.
    If I were in your shoes, I'd get one from the factory that matches the gauge, unless you can verify it doesn't matter.
  5. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Get one from the dealer. I trashed mine a while back changing out the exhaust and had to get one from KW.
