ELD EXEMPT
Discussion in 'Experienced Truckers' Advice' started by ak1986, Jan 13, 2018.
  1. ak1986
    ak1986 Bobtail Member
    Any advice what to do or w.e we have coronado glider 12.7 series 60 but since this was bought at Texarkana Freightliner so Engine was remain and rebuilt by Detroit wich came out with new engine serial# and engine model # so if we search by serial # it will say its 2014 and everyone knows its EPA 04/98 but they CANT probably they dont don’t wanna dig into it and all they say is its manufactured September 2014 and they have no any history before that....any suggestions or any help is greatly appreciated...
    Thank You
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    This is BS.
    Remove the engine tag. You do not have a warranty.
    Grubby Thanks this.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    The officer has to prove that the engine is post 2000, you do not have to prove that it is not.
    It's all on the DOT's shoulder to prove their case.
    Tall Mike, Grubby and Manitoba farmer Thank this.
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm in same predicament.
    I got a 16 ws glider with ddec4 in it.
    Built date on engine says September 2015. Engine is manufactured in late 99. Reman serial # says 2015.........
    Kinda pissed off .
    Detroit is no help
    Grubby Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,601
    13,322
    Jul 6, 2009
    Maybe that's the new regulation.
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm almost thinking of getting a serial # off a 98 or 99 series 60 from salvage yard and getting the stickers reprinted at Detroit.. put them on my valve cover.
    duckdiver, Grubby and Oxbow Thank this.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Silly question. Does the engine have a dpf, or any emission controls?
    The guidance states Engine Model Year, not engine build date. You are likely NOT exempt for that reason.
    And the same guidance states if the officer cannot determine engine model year, they are to refer it up the chain. Once that person comes out to look over the required paperwork, do you think they will be willing to overlook any other errors in the paperwork?
    No, go get an older truck if you want to be exempt for that reason...
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I pulled my new reman engine serial tag off my block today. Under the tag was the old serial # still stamped into the block...It's the same number but with out the 0 in front..
    So if they reman a old engine they just put a 0 in front of the original serial #.
    O6RE142873 is new reman number
    6RE142873 was old original number.
    I' going to try giving Detroit the old number and maybe they can give me the original build date.
  10. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Aren't the exemptions only good for the next two years?
  11. ZVar
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Date based exemption has no time frame. It's a truck stop rumor.
    Only exemption going away is the ag exemption, and the OOS for no ELD (which is voluntary by state anyway) and those are both about April 1st
    All other exemptions are staying (until FMCSA decided to go through the whole rule making process again to remove them)
