Electric horn wont stop on Cascadia
Discussion in 'Freightliner Forum' started by ETF, Mar 14, 2014.
  1. ETF
    ETF Bobtail Member
    4
    Mar 14, 2014
    I spilled water on my steering wheel, and now my horn won't stop going off. I tried disconnecting it at the steering wheel, but it still kept going off. I then tried pulling the fuse, but to my dismay, that fuse also controls the my cruise control and instrument cluster, so that won't work because I won't be able to know my speed while driving. I'm hoping it dries out by the time I need to hit the road and it will be fine, but if not, I'll need to disconnect the horn some other way if possible. Any suggestions?
  3. snowwy
    snowwy Road Train Member
    20,527
    13,265
    Jul 6, 2009
    disconnect the wire at the horn itself.
    how often does that horn get used anyways. vs. the air horn.
  4. ETF
    ETF Bobtail Member
    4
    Mar 14, 2014
    I don't really know where the actual horn is.
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Does your truck have airbags? If not, just open up the steering wheel. You could also find where the electronic horn actually is and cut the wire there.
  6. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Lift the Hood,(I trust you've learnt how to do that in the last 9yrs) ..LOL.. the Horn will be the "thing' making all the noise... Pull the wire off the 'thing" = noise gone...
    Truckinchic, WitchingHour and magoo68 Thank this.
  7. Grumppy
    3,063
    10,438
    Dec 11, 2010
    West Monroe, La
    "Maybe I am just blowing my own horn" but don't you need that horn during an inspection? I can not specifically remember, but I think you're required to have a "city" horn & it gets checked in roadside, Level 1 & Level 2 inspections.
    Therefore, I wouldn't suggest unplugging or disconnecting it for any length of time.
    Correct or not?
  8. Truckinchic
    Truckinchic Medium Load Member
    311
    299
    Apr 8, 2012
    MA
    Its shorting out..Try to get it fixed before cutting any wires..last thing you need is a truck fire caused by shorting out wires..even though it started after you spilled water on your steering wheel , something else could be the cause. Water could have kicked it off, but have it checked.
  9. ETF
    ETF Bobtail Member
    4
    Mar 14, 2014
    I wasn't really able to do that because I was parked near other trucks where drivers were sleeping, plus it was dark. Anyways, I guess it dried while I was sleeping because I put the fuse back in and it's not going off now.
  10. ETF
    ETF Bobtail Member
    4
    Mar 14, 2014
    You're correct. I was told during an inspection that anything that you have on your truck even if it's not something that you're required to have, has to be in working order.
    Grumppy Thanks this.
  11. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    You need one to be working.
