I'm dealing with small static discharges through my laptop while using it.
I'm using a surge protector plugged into an outlet in the bunk. How do I ground it and shouldn't it already be grounded?
thanks
Electrical issues in Cascadia?
Discussion in 'Questions From New Drivers' started by Phenomenal, Dec 17, 2019.
Try another ground wire from the cab to the frame. Older trucks it's a common problem, electrical gremlins, and I'd start with a good ground.
Phenomenal, truckdriver31 and LDLWells Thank this. -
Phenomenal and truckdriver31 Thank this.
Phenomenal, Dave_in_AZ, lovesthedrive and 1 other person Thank this.
Phenomenal Thanks this.
Yes, some laptops do not get along with a Modified Sine Wave inverter.
Phenomenal and truckdriver31 Thank this. -
16 gauge wire will carry 20 amps. 16 gauge is very common in the wiring. The desk your using the laptop on is plastic, so no grounding there. Rubbing long sleeve shirts on the plastic will generate static.
Otherwise cook more coffee. A higher humidity will lessen the ability to create a static electricity discharge.Phenomenal Thanks this. -
You should not have any discharge at the laptop, that's why I asked my question. You are using two different isolation power supplies with a common ground that is created through the system.
Grounding it doesn't address the issue.lovesthedrive and Phenomenal Thank this. -
thanks for all the replies
2019 cascadia btw
ya, the source of power to the bunk is via the inverter
no visible spark when I handle my chromebook but a decent static shock.
i too suspected low humidity in the truck may be the cause but how do i remedy it
i'm afraid i going to fry my chromebook...it froze the other night after displaying weird pixals
(never did that before). I had to reboot.lovesthedrive Thanks this.
