Electrical problem 379
Discussion in 'Peterbilt Forum' started by MSS, Jun 21, 2016.
  1. MSS
    MSS Light Load Member
    83
    22
    Feb 16, 2008
    Hagerstown,MD
    Ok guys need your expertise. When i turn on my cab marker lights (on its own switch) the left turn lights come on and the left blinker does not work. With cab lights off the cab lights blink with the left turn signal... go! 2004 379
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,534
    6,597
    Aug 26, 2014
    Normally a broken filament in a bulb causing a short. Unplug trailer cord and test. Trailer end first and truck end second. Then left tail light, LF turn, mid turn. Easiest to unplug first. Isolate and fix the problem. Could be a bad ground on a light also.
  4. agitator
    agitator Light Load Member
    65
    80
    Apr 21, 2012
    Sounds like a bad ground....but definitely check the rear tail light bulbs...had a similar thing happen and it was just a tail light bulb..
  5. MSS
    83
    22
    Feb 16, 2008
    Hagerstown,MD
    Found the problem my pigtail wires were all screwed up, so easy fix this time.
