electrical problem T600 - 2003
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Apr 13, 2014.
  1. rollin coal
    rollin coal Road Train Member
    13,240
    26,556
    Mar 29, 2008
    TN
    Strange problem with my truck. I go out to it a few minutes ago to grab a few things and it's dark out. I need a dome light so I flip the switch and nothing. Not a single map or dome light in the cab or sleeper will come on... I figure I left something on over the weekend and the batteries went dead so I try to start it. Fires right up. Voltage looks normal. Headlights, marker lights, turns all of those work like normal. But no map lights and also no 12 volt cig plugs working. Let the truck run for a while all of a sudden I hear what sounds like low voltage beeper beeping. It comes and goes. Sometimes it would change tone. I'll check the fuses in the morning. Hoping it's something simple. Anyone have this problem before? If it's not fuses what to check and look at?
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Wire has broken at low v. cut off
  4. rollin coal
    13,240
    26,556
    Mar 29, 2008
    TN
    Where is low voltage indicator located?
  5. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    Was behind R door rear panel, like where seat/belt winds up thru slot,listen for it to be sure?
  6. rollin coal
    13,240
    26,556
    Mar 29, 2008
    TN
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    In my 05, which should be the same dash/interior as yours, my low voltage alarm was up above the windshield in the dummy light cluster.
  8. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    Only one of my neon is dead off. Have to replace it. Also replaced windshield wiper assembly 2 years ago. Only salt is my problem for exterior lights.
  9. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Rollin coal did you ever figure out your electrical problem on your t-600?
  10. rollin coal
    13,240
    26,556
    Mar 29, 2008
    TN
    Low voltage regulator. Bypassed it.
    wore out and SAR Thank this.
