electrical problem
Discussion in 'Peterbilt Forum' started by rebel-yell, Dec 13, 2014.
  1. rebel-yell
    rebel-yell Bobtail Member
    7
    Dec 13, 2014
    dalhart,tx
    my dash lights are not working and guages ain't working either
  3. FLATBED
    FLATBED Road Train Member
    How about giving a HINT on the Year and Model in case someone had the same problem
  4. rebel-yell
    7
    Dec 13, 2014
    dalhart,tx
    I'm sorry I thought I had it in there but its a 2006 379 short hood pete
  5. aplustrucking
    aplustrucking Bobtail Member
    31
    Nov 19, 2014
    Sayre, Oklahoma
    Switched accessory fuse in the fuse panel
    rebel-yell Thanks this.
  6. rebel-yell
    7
    Dec 13, 2014
    dalhart,tx
    is that the only thing or could it be somethin else ? just askin to cover all the possible things
  7. aplustrucking
    31
    Nov 19, 2014
    Sayre, Oklahoma
    If you have dome lights and the truck will start its either a fuse or wiring. The truck should have several fuses for switched or unswitced accessories should be labeled sw acc or unsw acc
  8. rebel-yell
    7
    Dec 13, 2014
    dalhart,tx
    OK thank you I'll check when I go back out there later
  9. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    My light switch is needing some attention this weekend. Can't dim the lights and just run clearance lights. Must have a bad ground in the marker only position. I went to dim my headlights coming into the truck stop tonight and you could hear it arcing and everything was flickering. Luckily headlights side of the switch is holding up. I'll clean it up, and check the contacts. Hopefully it's a quick fix.
  10. rebel-yell
    7
    Dec 13, 2014
    dalhart,tx
    i hope it is too cuz i dont want to put it in the shop for anything the shop here isn't very good
  11. icsheeple
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Seems to be the trend. They'd probably replace your ECM, then say. We couldn't find the problem, want us to keep replacing parts till it's fixed?
