Electro-Voice 602T noise cancelling microphone
Discussion in 'CB Radio Forum' started by rabbiporkchop, May 4, 2016.
  1. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
  3. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
    OK....I pick it up. now the fun part.......who's going to wire it for a 4 pin ? Chris @ The CB shop in Ontario ?
  4. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
    btw Rabbi, thanks for the fine :)
    rabbiporkchop Thanks this.
  5. mike5511
    mike5511 Road Train Member
    3,141
    1,523
    May 15, 2011
    NW Arkansas
    Dang, missed it!
    Diesel Dave and rabbiporkchop Thank this.
  6. Ridgeline
    22,365
    115,985
    Just an FYI, some of these have three wire cabling, which means they don't work with modern radios.
  7. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    I can give you step by step wiring Instructions.
    pin 1 shield
    pin 2 audio
    pin 3 transmit
    pin 4 (cobras only) receive
    Diesel Dave and NJTrucker Thank this.
  8. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    The EV 602 series switch is always compatible with all modern radios including Cobra and Uniden and although the pj-068 plug uses 3 wires, a 4 pin plug and 4 wire cord can easily be added. Here is one from my personal stash opened up to show the switch.
    (Unkeyed it makes contact for cobra receive
    and keyed you can switch audio and transmit although I only switch transmit and leave the audio wire permanently connected on mine)
    This one came with a 4 pin XLR
    This microphone uses 3 wires and works fine with modern radios.
    Pin 1 shield
    pin 2 audio
    pin 3 transmit
    pin 4 empty
    (Will not work with cobra or uniden.
    This will work on exports only)
    Reason for edit: pj-068
  9. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    Did you end up buying it?
  10. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
    Yes I did. Comes in Monday.
  11. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    When you get it shoot me a p.m. and I'll send you my number because I'll have to guide you through the process over the phone but you'll need flux solder and a soldering gun and some wire strippers
    Diesel Dave Thanks this.
