Electronic logging?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Simpleman2go, Sep 25, 2018.
  1. Simpleman2go
    Simpleman2go Bobtail Member
    6
    Jul 11, 2018
    I’m about to start hotshotting with a truck and trailer under 26,000 lbs. Can anyone tell me if I have to use the electronic logging or can I use paper logs?
  3. brian991219
    brian991219 Road Train Member
    2,999
    6,091
    Aug 10, 2013
    Lords Valley, PA
    It depends, are you going to operate in interstate commerce, meaning under a US DOT and MC number or are you only going to run in one state?
    If you are running interstate then the Federal hours of service regulations including electronic logging devices fully apply to all commercial vehicles over 10,001 pounds gross weight rating. That said, there are some commodity specific exemptions as well as age of equipment.
    If you are running only in one state you need to check with them. Some have exceptions for under CDL trucks, and some may not have adopted the ELD rules yet.
    SixShooterTransport Thanks this.
  4. Simpleman2go
    6
    Jul 11, 2018
    Ok thanks, I am running with a dot number and mc number. Do you know of any iPhone app logging devices that are dot compliant?
  5. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,541
    May 22, 2017
    Keep trucking app.
  6. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    Its not just the app that you need, you also need a device that will connect to the trucks ECM to be ELD compliant.
    brian991219 Thanks this.
  7. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
  8. Makeajump
    Makeajump Medium Load Member
    443
    363
    Apr 19, 2014
    Texas
    TransFlo ELD available at Love’s Truck Stops .......
  9. brian991219
    2,999
    6,091
    Aug 10, 2013
    Lords Valley, PA
    Being a hotshot truck under 26k I assume you are using a pickup truck. Be very careful selecting an ELD, most do not work well, if at all, with light duty engines.
    Also, as someone who sells ELDs (please don't shoot the messenger) many do not work well with iPhone interfaces, so you might want to get a stand alone device. Personally, I am not comfortable handing my personal phone over to a roadside enforcement officer, too many things can go wrong even accidentally.
    Bank_Lbr Thanks this.
  10. brian991219
    2,999
    6,091
    Aug 10, 2013
    Lords Valley, PA
    Good to know. Apple is a tough platform to develop interfaces for, they keep everything so secret. many of the ELD makers have had trouble with the interface, glad someone has it figured out.
    Does the Deleted support light duty engines using the automotive OBD-II communication protocol or only heavy duty diesels using J-Bus and heavy duty OBD-II?
