Electronic "Noise" Question
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by STexan, Sep 26, 2017.
  1. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    When you plug in a particular device into a cig lighter port, and you see the RF meter on the CB radio go up significantly, is this "noise" being transferred through the power supply or via the antenna RF?
    I'm having trouble finding a quality cig lighter > USB adapter that's not "noisy". (If there is such a thing). Even on separate circuits I'm having the same issue.
    Would a noise limiter at the CB power source help?
    rabbiporkchop Thanks this.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    Disconnect your antenna... is the noise still there? If it is, the noise is coming through the power feed. You can try a snap on ferrite choke over the power feed for your radio.
    If the noise goes away, try shielding the plug by wrapping it with aluminum foil. It's the noisy switching power supply that's generating RF.
  4. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    I have this one hard wired into my Tahoe with zero noise.
    It might be worth trying.
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Hhhmmmmm...My gps and cell chargers make a good nit of white noise..Ill have to look into it...
    Im sure its the same idea as the big inverters maken noise..Its called dirty power...Wonder if an rv shop would have the ciggy lighter type..
