Elogs and paper at the same time
Discussion in 'Questions From New Drivers' started by WhyDriveTruck, Jan 9, 2015.
  1. WhyDriveTruck
    WhyDriveTruck Light Load Member
    272
    60
    Sep 1, 2013
    Detroit
    Greetings everyone
    Ok this may seem odd but please allow me to ask.
    Ok my company just put and elog tablet in my truck then they also want me to transcribe my elog on too paper , if my memory serve me correct we aren't allowed to have 2 logs. Please correct me if im wrong
  3. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    You cant legally run two logs... If you get pulled over, and hand the officer your Qualcomm and your paper logs you may still get a ticket even if they match
    That being said, on our week out with a driver at SNI, we kept "two" logs. One was the legal log and the other was the, "do you know what you're doing" log. If your company is asking that of you i would be curious to know why.
  4. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    Is it a log if you don't sign it or fill out the pertinent info like truck number, carrier, etc? Or what if you write SAMPLE, PRACTICE, or even VOID over the graph.
    chalupa Thanks this.
  5. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Nothing wrong with two logs as long as they are identical.
  6. TNMT
    TNMT Light Load Member
    226
    229
    Nov 11, 2008
    Front of keyboard
    You should always carry paper logs in the truck even if you have elog. If elog fails for whatever reason you have the ability to log right then and there. I had to do paper logs and elog at the same time once. The company wanted to cross match both to insure there was no bugs in their computer logging system. A select number of drivers had to do it before they would put the system into place before going company wide. The paper log was the official log when driving. The elog was not because it wasn't being used by the company as the official logging system for compliance. Which ever one is being used for auditing by your company is the one you hand to DOT.
    bobtrucks2204 and JReding Thank this.
  7. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Wrong. There are actually circumstances where the regulations may REQUIRE you as a driver to have multiple logs (i.e. if you drive for multiple carriers, EACH carrier needs a RODS from you with THEIR company info on it to keep on file). As long as the time grid and notations all match up (adjusting for time zone differences if needed), it is perfectly legal.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    You're going to have to use paper with Elogs, what if 10 hours into you day, your Elog quits, what are you going to do then?
  9. dptrucker
    dptrucker Road Train Member
    4,683
    3,199
    May 14, 2012
    adelanto,ca.
    swift has the trainees use paperlogs and elogs while with the mentors. swift has them write sample practice on the paperlogs. elogs are the logs they show to dot.
  10. Ebola Guy
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    Start with fresh 11/14! What else?!
    Mudguppy, ErikN and A21CAV Thank this.
  11. nshore harleyguy
    nshore harleyguy Medium Load Member
    342
    258
    Feb 8, 2014
    NH
    I had my logs checked when my qualcom had been malfunctioning. I had been on paper for 2 weeks and had just had my qualcom replaced. I decided it would be smart to at least finish that day on paper before going back to the qualcom. I had paperwork to prove the qualcom was replaced just hours before. The DOT officer understood (thankfully I had paperwork to prove the QC had been replaced just hrs before) that and he was fine with it. He explained that it IS actually legal to have more than 1 logging system but they must match perfectly. If there is any difference between the 2 you can be in big trouble. I didn't ask what the penalty would be he just used the words "big trouble"
