Elogs..The good,The bad and the ugly truth
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Storm1014, Mar 28, 2014.
  1. Storm1014
    Storm1014 Bobtail Member
    41
    14
    Jul 1, 2012
    Drivers...Since Elogs have been put into use I have heard some good,some bad and what I refer to as the "Ugly Truth".
    I have used Elogs once at 1 carrier I was with,They claimed that they "Preplan" every load for you..That lasted about 3 months,guess I got lucky.
    I talk drivers daily and have had numerous discussions with drivers of all experience levels,Alot of them had told me that since they`ve been using Elogs,Their income has dropped by $3000 to $7000.00 a year,lack of miles Etc.
    I also see about the same amount of wrecks daily,Were n`t we told by the Fmcsa that the "Elog" would reduce accidents and make the highways safer. I see no change.
    Just saw a Walmart truck filpped on its side near Blacksee,Pa this week coming across I-80,Local radio reported driver fell asleep and flipped the truck,Yes I know.... A "Walmart truck"...Rare sight... This week,I believe it was wednesday 03/26/14
    Being An experienced driver I know when I get tired,common sense tells me to pull off the road and go to sleep,no load is worth your life.
    I also have to ask this question,How many drivers have seen a realistic pay increase since this inception...My thoughts are if they mandate the elog thing,drivers should have a higher mileage rate,I feel it should be minimum .40 cpm to start,5 years-.45 cpm,10 yrs .50 cpm and up.
    Now I know we all don`t agree,but some common ground needs to be put in place.Unionization is not the answer,and I know some might argue that.Please share your thoughts.....
    :dontknow:
    Joetro, TwinStickPeterbilt and pattyj Thank this.
  3. realsupatrucka
    realsupatrucka Road Train Member
    2,072
    513
    Sep 25, 2013
    houston tx
    I definitely agree pay should be higher....when I first used a elog I took a loss until I actually learned how to use it...but it saved my cdl....I was one to run run run...so im kind of glad e logs are in effect now...trying to match fuel recipes and 34 hours breaks and times in 3 logs books are not easy...but I still run 2800 to 3500 miles a week on e logs
  4. peterd
    peterd Medium Load Member
    349
    365
    Jan 7, 2012
    St.Catharines ON
    I can't speak for other drivers and their experience with e-logs and pay going down,but I have been with Bison for 9 years and on e=logs for the last 3 years and my pay has not dropped at all.My 1st year with Bison made $70,000 and the last 2 years made just under $80,000.
  5. socal
    socal Medium Load Member
    574
    348
    Feb 18, 2008
    Los Angeles CA
    What happens on Elogs when your headed home and run out of time 70 miles away?
    What happens when you want to stop and take that pretty lady out to dinner?
    they stink and make you nothing more than a robot. When they start paying a Salary per day and dispatch takes on the headaches then I am in.
  6. notmycbhandle
    notmycbhandle Light Load Member
    54
    45
    Jan 18, 2014
    Cowtown
    THE GOOD:
    Usually it tells you before make a mistake so you never have to worry about compliance (the violations mentioned below had to do with not filling in all the windows properly). You don't have to worry about turning in logs or making sure you remember to grab an extra book. Oh and your dispatcher can't tell you to grab a new book and keep running.
    THE BAD:
    I haven't been on e-log a full year yet but I do know that I'm seeing less home time for sure used to have 7-10 off per month now it's 2-3 and I'm barely making the same money. I also know that I've had 4 form and manner violations (3 more than in the previous 19 years of paper logging combined). I also find myself driving in rush hours and borderline fatigued states more than ever before. I also feel somewhat disconnected from my book, I find myself not knowing without looking how many hours I have left or what I get back tomorrow unlike when I used paper where I could almost recite what I had for the next 3 days.
    THE UGLY TRUTH:
    The truth is elogs highlight for everyone to see the problems with the hours of service. It's a shame that the only people seeing the problems with them are drivers and a few guys in safety and compliance departments
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    It's all about control....... Nothing to do with safety .
    Micro managing the driver..
    P.S. Still on paper, however the days are numbered .
  8. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    I've ran e-logs while running LTL linehaul and didn't make any less or any more money with them. However the LTL operation I ran with ran strictly legal and all the runs were set up to be that way, unless something unforeseen happened, breakdown, bad weather, etc. . Did snafu's occur from time to time, sure did, but even then they would not let us run illegally. Say for instance we had a breakdown and ran out of hours, they would either make us get a motel room or come to get us and the truck, if we were close enough to a terminal. While that job was not paid hourly it was a combination of hourly, flat rate (for D&H's) and mileage my pay didn't go down when they switched to e-logs, it went up by the amount of the annual raise they gave us.
    That being said, the last company I worked for will be screwed when e-logs are mandated or they will just close the doors. At that company the only way to make money was by running at least 70 hours/week, most times one was expected to run past 70, hours of service were not an excuse to not do a run there. This is the same company that essentially fired me (claimed they had no work for me) when I put my notice in when I found another job. If a driver refuses to run over hours they simply cut that drivers workload significantly forcing him to move on to greener pastures, that's what I had to do.
    E-logs however are not a guarantee that a company comply with HOS rules though. CTI, Cryogenic Transport Inc. (division of Kenan) out of Monclova, Ohio runs e-logs and regularly manipulated drivers logs to keep them "compliant". The terminal manager would change drivers start times the following morning after they had to run over hours to get back to the terminal more often that not. I know that it is a driver's responsibility to remain compliant even if the company tries to run them over, but we're all adults and know that the real world doesn't always work out like that.
    I feel for the OTR guys who aren't being paid what they should be. The e-logs will just cost them more money because once that clock starts ticking there's not much you can do to gain much extra time. One solution would be for the time spent at shippers or receivers to stop the 14 clock, to not have those hours count against the driver would make things better for everyone. Another possible solution would be to PAY drivers for that wasted time picking up or delivering loads over and above the mileage pay if the feds don't want to extend the 14 hour clock.
    Sadly, nothing will change without even more government intervention which is something I'm totally against because our government could screw up a wet dream, heck it's proven it can't even run a brothel without screwing it up.
    For me, the solution was to get a local hourly job running haz mat tankers, vans, roll off boxes, etc. It's a teamster's job (that's good and bad) it pays pretty good $19.25/hr to start with time and a half over 40 and double time for Sundays and on call time, union bennies and retirement. This job isn't for everyone, some actually do not want to be home everyday, some don't want to mess with this much haz mat (almost every load), I get that, what may be a great job for me might not be for someone else. That's why we have to weigh what we want against what we can tolerate and make the best out of any job that we can be relatively happy at. Change for the better always happens at a MUCH slower pace than change for the worse and it definitely seems we have been on the down hill side of bad changes for some time now.
    25(2)+2 Thanks this.
  9. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    Not much trouble due to e logs , they have definitely forced the dispatchers to tighten up and plan better.
    Pay appears to be unaffected
  10. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    I'm on elogs...just got .02 cpm raise and getting another .07 cpm in six months. Turned 3k miles last week too
  11. CrappieJunkie
    3,982
    18,763
    Mar 9, 2014
    SoCal plan better so that doesn't happen.
