Hi all,
I am building a custom POI for Emergency Runaway Ramps and Mandatory Brake Check Areas. If you would like to list here the ones you know about I would appreciate it
Please try to include the following (This is for the US and Canada)
City/State
Road/mile marker
Direction
Lat/Long if known
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by mattbnr, Sep 10, 2014.
Page 1 of 3
Suggest you call each state,,Colorado,,calif,,OR,Wash have them, ,, In some countries they are called "arrestor beds"
I've seen them. But never used one.
Lucar Thanks this. -
Right. Because I'm going to search my GPS for the nearest runaway truck ramp when I'm headed downhill and my brakes fade away...
Seriously though, why would someone want a POI file for those? Those things are always well identified with regulatory and advisory signs when you're on a route that has them.lovesthedrive, semi retired semi driver, dukesings and 1 other person Thank this. -
No, but you'll know they're there before you start descending in case zhitz
I run mostly at night and can't usually use a break check area because a bunch of a-holes are parked there for 10hr breaks. I guess the OP wants to be able to plan to park overnight at a break check area by making this POI. That is the only reason I can see why. The are usually well marked a few mile out and same for the runaway ramps.
windsmith Thanks this. -
wow if you cant see a brake check area or escape ramp you don't need a poi you need some freaking glasses.
semi retired semi driver and MachoCyclone Thank this. -
POI's are build for many reasons.
Everyone has something to say, but no one is helping the op out..mattbnr Thanks this. -
Sorry I can't give you the mm, but just east of Monteagle, TN, I-24. As previously mentioned, the runaway ramps are on the left. The mandatory brake check area is on the right.
Page 1 of 3
