End dump rear axle locking brakes up at 5 psi... REWARD OFFERED!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JCMtrans, Dec 2, 2017.
  1. JCMtrans
    JCMtrans Bobtail Member
    45
    27
    Dec 29, 2016
    Good afternoon, I hope everyone is having a great weekend, and thank you in advance to anyone who is willing to take time out of their lives and busy schedules to read my post! I'm just about done pulling my hair out over this trailer. I've got a 1993 Lufkin frameless end dump with Neway trunnion-type suspension. I pull it with my 1997 FLD120 Freightliner with 3406E Cat. Shortly after buying this trailer earlier in the year, I noticed that it was becoming easy to lock the brakes up on the back axle only, somewhere in the neighborhood of 20psi empty. I noticed the shoe linings were well worn, so I had a shop rebuild all brakes, including new s-cams, bushings, new shoes, new drums, wheel bearings, wheel seals, and 30/30 round port standard brake chambers. The problem still persisted, and the brakes would lock up easier now, just on the back axle. If I backed the slack adjusters off almost as far as they would go, no brake lock-up, of course. The front axle on this trailer never locks up. Even at 50psi of brake application pressure, no lockup. Replaced relay valve, and spring brake valve. Same problem. Replaced trunnion bushing. Same problem. Replaced brake hoses, same problem. I then started with Bendix' tech team to troubleshoot my problem. They seemed to think the shop who rebuilt my brakes used wrong parts. I hunted down my original equipment information on my Dana/Spicer axles, now having to talk to Hendrickson due to them now owning Dana. I rebuilt one side of my back axle's brakes, including new shoes, drum, s-cam, and s-cam bushings. Same problem persists. I can be driving down the road with all brakes adjusted 1/4 to 1/2 turn out, 55mph, apply the brakes and the rear axle alone will lock up at anything greater than 5 psi. No kidding. It is nothing to lay 1/4 mile of rubber with this trailer just trying to slow down. I have to turn out those slack adjusters over 2.5 turns on the back axle to get it to not lock up. I'd like to use my trailer and put it to work, just having this major issue. The dealer that used to sell these Lufkin trailers took a look at it and could not figure it out, only suggested that my trunnion is having some issue and recommended replacing the trunnion tube, bushing, and all cast iron parts just to make sure it is within spec. To the tune of several thousand dollars. Anyone with the problem-solving idea will get a $50 gift card, and I'll probably make it more to express my thanks!! Has anyone had a similar issue with a center pointed trailer?
  3. JCMtrans
    45
    27
    Dec 29, 2016
    I should mention that today I rigged up an air hose from my framing nailer with an air gauge, and tested pressure at the gladhand and at the brake air hose coming from the ports of the relay valve on the trailer. No pressure spikes, if I gave 5 psi of foot feed pressure, the gladhand showed 5psi, and pressure from the relay valve also showed 5. All the way up to 50-60psi. I also replaced the spring brake valve, which was an SR5 and replaced it with a Sealco 110700, which has an anti-compounding feautre built in. Still no fix.......
  4. Rickp
    Rickp Heavy Load Member
    765
    1,070
    Apr 14, 2016
    Ward, AR
    In the 90s when i ran end dumps we had this issue a lot with a couple styles of trailer. We all kept the brakes on every axle, tractor and front trailer, adjusted up tight except the rear one which we adjusted to just barely legal. Didnt completely eliminate the problem when empty but kept it from happening on the more gentle braking times.
    JCMtrans Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,470
    6,507
    Aug 26, 2014
    I suspect mismatched parts: Drums to hubs, cams to shoes, shoes to drum type thing.
    You could possibly install a steer axle ratio valve inline to each of the rear chambers. The one with only two ports QR 3 or 4? They limit application air during light braking but are full on during heavy braking. There are at least three different options in the amount of regulation. I would use two instead of the one as on the steer axle because the chambers are larger and need more air flow.
    Just a thought as I have never seen this done.
    bigguns, Oxbow and JCMtrans Thank this.
  6. Heavyd
    Heavyd Road Train Member
    7,770
    6,210
    Feb 4, 2009
    I know this sounds weird, but I have seen the suspension lock up in such a way that most of the weight would only be distributed on one axle which made the other axle basically just a floater. Since it had no weight on it, the brakes would lock up every time even with a small brake application.
    BoxCarKidd, SAR, Tb0n3 and 3 others Thank this.
  7. BoxCarKidd
    4,470
    6,507
    Aug 26, 2014
    Bendix LQ 4. It has 3/8 ports.
    bigguns and JCMtrans Thank this.
  8. Oxbow
    Oxbow Road Train Member
    12,805
    132,556
    Nov 24, 2015
    I would have to suspect problems in the trunnion as well, given that you have replaced all the brake parts.
    When dumping with the bed all the way up, does the front axle come off the ground, or do both stay on the ground?
    It might pay to jack up the trailer on the framework that the suspension attaches to and see if the axles easily articulate.
    I am just grasping at straws here; good luck with it.
    SAR, Tb0n3, JCMtrans and 1 other person Thank this.
  9. CaseRobert
    CaseRobert Bobtail Member
    21
    19
    Apr 21, 2014
    Otsego, MI
    did you also replace the front axle shoes, drums etc. or only the rear? I wonder if something on the front axle is causing the front brakes to not apply as much as the rear axle.
  10. JCMtrans
    45
    27
    Dec 29, 2016
    Thanks for all the great advice and ideas, I was gone all weekend and finally last night was able to get back and jack this thing up in the air directly under the trunnion, which would have logically lifted both axles off the ground at almost the same rate..... I almost couldn't believe my eyes when the front axle stayed on the ground and the back lifted up....almost 2 feet in the air before the front axle lifted too. With both axles in the air I jumped onto one of the back tires and it would only spring down about an inch as I jumped up and down on it....believe me that trunnion is locked up TIGHT..... I don't have any idea what could cause a brand new polyurethane trunnion bushing to store that much torsion in it and lock up like it has, but here we are... It took a floor jack with some wood blocks under the front axle and almost all my weight on the jack handle to jack the front axle back up, it was squeaking and creaking all the way when we could get it to budge. Jacked it to where it was level with the back, test drove and wouldn't you know it.... took 10-15 psi this time to lock up the back axle. Still locks up, and I'm probably just going to trade this thing off, but it helped significantly! Not sure if I want to spend the money on a whole trunnion replacement....
    BoxCarKidd, bigguns, Heavyd and 2 others Thank this.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Congrats. You now get to pay yourself with a gift card. Enjoy. You earned it. Who would have ever thought that would be the problem? Could the problem be something as simple as over torqued trunnion bolts pinching the cross tube thereby not allowing it to move freely?
    Think about the trailer suspension when the trailer is dumped. The front axle will be forced down while dumping (think teeter totter or see saw type action). When the trailer drops to the ground the front axle will pick up the weight because it is first to touch the ground leaving the rear axle light and causing it to skid. I hope my explanation makes sense.
    SAR and BoxCarKidd Thank this.
