End dump: what am I missing.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Humblepride, Jul 29, 2014.
  1. Humblepride
    Humblepride Bobtail Member
    6
    Ok so I had someone tell me 103.00 per ton to go just under 1100 miles
    the product is crushed limestone.
    Whos paying to ship this and how are they making money off of
    one load of stone? What's it used for? Can't be retail. Just curious
  3. Chinatown
    Chinatown Road Train Member
    74,885
    170,636
    Aug 28, 2011
    Henderson, NV & Orient
    [h=2]USES OF CRUSHED LIMESTONE[/h]1) Road Base
    2) Under slab fill
    3) Aggregate for making concrete
    4) Sand for making concrete
    5) Aggregate for mixing hot mix asphalt
    6) Sand for making hot mix asphalt
    7) Chip seal aggregate
    8) Railroad Ballast
    9) Agricultural Limestone (Aglime) neutralizes soil acidity and a source of calcium and magnesium
    10) Rip Rap for erosion control
    11) Bedding for Rip Rap
    12) Bedding for underground pipe
    13) Back fill retaining walls
    14) Scrubber stone (removes sulfur dioxide in power plant exhaust gas)
    15) Used to neutralize acid waste
    16) Flux stone (making steel)
    17) Flux Stone (making glass)
    18) Flux stone refining sugar beets
    19) Feed stock making cement
    20) Feed stock making lime
    21) Neutralizes stomach acid (Tums)
    22) Ingredient in calcium supplement pills
    23) Ad mix in animal feeds
    24) Filler in paint
    25) Filler in roofing shingles
    26) Abrasive and filler in tooth paste
    27) Filler for making plastic pipe
    28) Aggregate for making concrete pipe
    29) Sports field drainage medium
    30) Chicken grit
    31) Aggregate in concrete blocks and bricks
    32) Aggregate for concrete power poles
    33) Dust to prevent coal mine explosions
    34) Landscape stone
    35) Boulders for car barriers
    36) Sediment Fences (filter media)
    37) Bio degradable flat ware (plates-made by molding limestone fines and corn starch)
  4. Chinatown
    74,885
    170,636
    Aug 28, 2011
  5. MOBee
    MOBee Road Train Member
    1,774
    10,159
    Apr 27, 2014
    Hmm, it is too bad it doesn't have more uses. ;-) Number 37, base for horse stalls.
  6. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    if you have one of them small light weight end dumps. and a daycab truck. $103 is doable.
    the ones i used to drive could haul 24 tons. X $103 = $2472. 78,000 pounds for bridge.
    can't see that being very doable with a sleeper truck and one of them tall heavy end dumps though.
  7. plow boy
    plow boy Bobtail Member
    36
    35
    Jun 17, 2014
    Always looked good till you got to the fine print or the settling up then it would be something like a "long ton" your actually getting paid freight on.
  8. 201
    201 Road Train Member
    12,327
    25,205
    Apr 16, 2014
    high plains colorado
    In Wisconsin, we have almost pure white limestone, and when I was a rock hauler, I talked to some guys that were hauling it to places (far away) where yellow or gray limestone is more popular. So it's entirely possible.
  9. Kw900a
    Kw900a Light Load Member
    55
    13
    Sep 29, 2011
    mifflinburg pa
    Its doable with sleeper truck my light weight is 34,000 w900 550 cat ravens dump. 22.5 x103=2317.50 ill use about ill use about 700 in fuel. Im a company driver and i can usually make my boss 5500 to 6000 a week before fuel with hauling some rates lower than that. The one week i hauled 5 loads that paid 80-100 a ton nice pay check that was
  10. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    I can average 23.75 ton with a half a tank in the 40footer i'm dragging.. it's way dooable... i was pretty amazed at the rates end dumps get when i started. Makes me want to buy a trailer and get my DOT# out of the moth balls
  11. wore out
    wore out Numbered Classic
    15,926
    192,761
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have pulled Lime in a hopper out of Midwest Lime in Batesville to a Maybelline make-up plant in Georgia. 103 a ton would be do-able I think
