Engine Block Heater on without Coolant in Engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2006 EGR Series 60 14L, Nov 14, 2021.
  1. 2006 EGR Series 60 14L
    2006 EGR Series 60 14L Bobtail Member
    4
    Nov 14, 2021
    While replacing EGR exhaust gas cooler, later learned the engine block heater had been accidentally switched on.
    IF it was indeed on after all coolant was drained and it burnt out, would it break apart and leave debris in the engine?
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    134
    Aug 31, 2021
    Not usually. The electrical element is what burns out, and it is encased in insulation and a metal casing.
    Pamela1990 and blairandgretchen Thank this.
  4. 2006 EGR Series 60 14L
    4
    Nov 14, 2021
    THANK YOU VERY MUCH for the reply, Ross! Maybe I will get a little sleep tonight after-all. ha
    And, After replacing the EGR cooler and refilling with coolant, I will check with an amp meter. I did check ohm's and do have continuity. At most, it was on for an hour without coolant, which is likely too long. Worry was debris. THANK YOU AGAIN.
    Ross_Tech and Pamela1990 Thank this.
