Engine Block Heater Problem .....
Discussion in 'Volvo Forum' started by Jeet, Jan 13, 2013.
  1. Jeet
    Jeet Bobtail Member
    24
    4
    Jul 17, 2010
    I have a issue with my engine block heater, i have just replaced the wire harness for the engine block heater, ( this is a dual type wire, on cummins isx, 07 volvo 670) one of the connection goes to the engine block heater on the right side, and second connector goes to water seperater on left side. Now every time i plug in the electrical plug, it blows the GFI breaker. What should i look for next ?????? could it be the block heater itself that might be causing ?????????
  3. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Could be, but there is definately a short.
  4. Mattchu
    Mattchu Light Load Member
    149
    24
    Sep 9, 2012
    New Bedford, Ma
    Check your cord you are using, does it only do it on the gfci or will it trips a normal breaker? gfci breakers can trip if there is any current coming back on ground....
