Engine bracket HELP!!!
Discussion in 'Peterbilt Forum' started by Trcknwolf, Jan 28, 2015.
  1. Trcknwolf
    Trcknwolf Light Load Member
    57
    27
    Nov 24, 2010
    Bellevue, NE
    I've got a '99 379 EXHD w/a 12.7 Detroit. I need to replace both the radiator support rod bracket & the PS fluid reservoir bracket. The radiator support rod bracket is a 2 piece bracket that goes over the valve cover on the front of the engine & bolts to the upper valve cover housing (I have the 2 piece aluminum valve cover, not the tall plastic cover). BOTH of these specific brackets are ONLY found on Pete's with Detroit engines. Anybody that can help me find there brackets I'd REALLY appreciate it.
    P.S: Peterbilt does NOT carry any longer.....
  3. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Did you try ebay? There are a few truck dismantlers on there.
  4. Jokingypsy
    Jokingypsy Medium Load Member
    669
    613
    Jan 4, 2013
    Have you tried Fitzgeralds Gliders. They have donor trucks that I beleive they sell parts off of, plus they are still putting S60's in 389 gliders, would be a good place to start your search.
    Adam
  5. Ringo1
    Ringo1 Light Load Member
    89
    131
    Apr 20, 2014
    South Carolina
    blairandgretchen Thanks this.
