engine brake and cruise not working
Discussion in 'Kenworth Forum' started by why me, May 22, 2011.
  1. why me
    why me Bobtail Member
    14
    May 22, 2011
    engine brake and cruise not working on 06 w900 cummins isx 475 replaced clutch switch and speed sensor , showing open circuit on clutch switch, ck pins at ecm to clutch switch its good any thoughts. thanks
  3. Bigray
    Bigray Road Train Member
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    make sure the clutch pedal is all the way out.
    from time to time the actual C-switch will go bad.
  4. why me
    14
    May 22, 2011
    thanks is there a circuit breaker or fuse for both.
  5. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    yes, and I think from memory they r the same fuse.
  6. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    yes, and I think from memory they r the same circuit breaker
  7. rnimmons
    rnimmons Bobtail Member
    orangeburg sc
    jakes and cruise not working on smart wheel 1999 kw 900l
  8. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    cant offer you much help, but...
    A friend with Peterbilt had to add alittle stronger clutch pedal return spring. A long shot, i am sure, but apparently it does happen?:biggrin_25514:
    Opps, little editing here. On more careful reading of thread, Bigray has already nailed this in #2. My apology's.
    Nitemare13 Thanks this.
  9. dmasonr
    dmasonr Bobtail Member
    make sure your grounded steering wheel to steering colum, and that your making contact to sensors (right side bottom by the johnson bar.
  10. KaptainKenworth
    KaptainKenworth Bobtail Member
    33
    18
    Jan 19, 2012
    Alberta Canada
    the clutch circuit is run off of a common wire ( ground) Same with almost all kenworth switchs!!! if the pin out from the ecm is ok then that circuit should not be the issue.. it would be best to have cummins insite hooked up and monitor all of your switch inputs..
    Brake ,throttle, clutch & switch inputs all come into play here.. it should be a failrly straight fwd diagnostic with a computer hooked up..
    does the unit have a smartwheel?
  11. MarkT.
    MarkT. Bobtail Member
    Is there suppose to be a hot wire going to the smart wheel
